Question about Cell Phones
Helloo there... i bought htc touch HD last year ... i was working fine then it sop making call . what i mean is it can detect the sim card but not the service !! i tried every thing soft and hard reset but no use , i dont know what to do ?? one of the tech told me that it could be the mother board but his not sure also ? so how i could make calls again is there any way i could fix it thanks
    President:
  • 1,561 Answers
the problem with your phone could be that the service antenna as broken, why don't you tell the technician to help you look at the service antenna if it is not the problem.
You can also visit another technician for his view about it because one of the major problem with phone with service issue is the phone antenna.
Check your phone service antenna to see if it is not the problem.
Guess the phone should still be on warrant, if it is, you can return it for service.
Take care.
Posted on May 07, 2010
My HTC wildfire won't recognize the sim card. Why?
There may be multiple reasons for the SIM not working/getting detected by phone.here are some remedies.
1.If the phone is locked(sim-locked/region locked)and not factory unlocked then the vendor specific SIM will work.you can not use different SIM provider with the locked phone.
2.check with different SIM cards whether they are getting detected by the phone and you getting signals properly.
3.if your SIM is working in another phone means the problem is in HTC simcard reader or any recent software update you applied on the phone.uninstall/rollback or factory reset the phone(remember this will delete the USER data so first take backup of sms/photos etc).
4.if still it doesnt help it means the phone simreader is faulty which is a hardware problem and you need to seek for service help.hope this helps.
Apr 03, 2015 | HTC Cell Phones
I want to unlock htc touch hd
You can Unlock it simple by using the Unlock code,You can get the Unlock code and instructions at here
moz-screenshot-1.pngTheunlockarena and Unlock it...You can follow the instructions below and Enter the code
HTC Touch HD Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HTC Touch HD mobile phones. If you enter over a certain amount of wrong unlock codes on your HTC Touch HD mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your HTC Touch HD with a Not ACCEPTED SIM Card.
2. If your HTC Touch HD asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Touch HD will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Touch HD is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your HTC Touch HD is locked to.
Jul 29, 2011 | HTC Touch HD Smartphone
How do i change my sim card in my touch pro 2?
I mean you need to Change to other Sim Card..?
if it locked means You need to Unlock it...If it unlocked means You no need to Unlock it..To Unlock the Mobile from the Network lock get the Unlock code here
http://www.onlinegsmunlock.com/htc-touch-pro2/rs7wp9/ and Unlock it....
Dec 21, 2010 | HTC Touch Pro2 Smartphone
I would just like to ask on what to do regarding on sim card missing. the sim works just fine with the other phones. i have tried several sims with the htc touch P3450 but it does not read the sim. it...
You have purchased a htc handset which will work only on a particular service provider like AIRTEL OR VODAFONE,
check your default internal memory ringtone section , whether it has airtel ring tone ....
then by that service providers SIM CARD , your hand set will work.
some times dual band sim cards dont work on triband service providers.handset
Aug 19, 2010 | HTC Touch P3450 Smartphone
UNLOCKEED TOUCH HD WON'T READ SIM CARDS
well i tried taking the battery out and i left it out for 3 hours and when the phone booted up i had service phone works great ....
Apr 18, 2009 | HTC Touch HD Smartphone
Htc 8925 error "sim card not detected" have removed and replaced sim card have removed battery and rebooted have swithed sim card to annother phone, works fine have replaced sim card with a working sim...
I see this is an older post but I wanted to post the solution that helped me after a very frustrating 30 minutes. I was having the same problem. I bought a new phone (HTC 8925), and when it arrived, I plugged it into the wall charger and inserted the SIM card. I still got the "SIM card not detected" error. After removing an inserting, checking all possibilities of having done it wrong, and searching the internet only to not find the answer, I tried something that worked.
My solution: When I unplugged the charger and reinserted the SIM card, it worked immidiately. It was as if being plugged into the charger was not allowing the phone to reboot completely, even though I was powering the phone down and back up again. Since this was the solution, if you are having the problem and not connected to a charger, I would try a soft reset by pressing the stylus into the button (tiny whole) to the right of the USB port.
Mar 23, 2009 | Cell Phones
Sim card missing for htc touch p3450
its a hard ware issue try putting a piece of paper over ur sim card to press it against the pins on the phone sometimes it gets loosen and does not detect sim cards or try restting the device as follows else go for service centre help but try these solutions first
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Feb 16, 2009 | HTC Touch P3450 Smartphone
HTC Touch - NO SIM
Make sure that the type of SIM you are using is compatible to the phone in the first place and that it is definately not defective.
If there is a fault, it may be the SIM socket in the phone, or a hardware failure between the socket and the internal processor system of the phone.
Jerry G.
Sep 22, 2008 | HTC Touch P3450 Smartphone
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
