Question about KitchenAid Superba KSRS27CN Side by Side Refrigerator
Kitchenaid Superba side by side refrigerator
I have a Kitchenaid Superba side by side refrigerator. The interior lights are out and the fridge is still running.
  • 6 more comments
  • slay11 May 07, 2010
    If only it was that simple. That was the first thing I looked at. The interior lights are out in the freezer and the fridge!
    I have a Kitchenaid Superba side by side refrigerator. I took out the ice maker, which is not working and now the interior lights are out and the fridge is still running. It is not something as simple as bad switches; I already checked that.
    It doesn't make sense to me that the bulbs in the freezer and the fridge burnt out at the same time. Is there anything in the ice maker that would effect the lights. The lights went out when I tried to remove the ice maker.
  • slay11 May 08, 2010
    All the lights are out (freezer and fridge) including the indicator lights in the fridge showing the freezer/fridge temps. Also the water dispenser and the light in the door stopped working. All this happened when I tried to take the ice dispenser out (which hasn't been working). Is there a fuse or relay in the fridge that could have blown?
  • slay11 May 10, 2010
    All the lights are out (freezer and refrigerator) There is also a compartment in the fresh food section that has lighted #'s showing such things freezer temp, fridge temp, # of hours left on the water filter; those lights are also out. Also the water dispenser on the door has stopped working. (this happened at the same time as the lights going out). The ice make hasn't worked for some time. When I tried to remove the ice maker is when the previously stated problems started.
    Sorry! I forgot to give you the model #. KSCS23INSS01
    There 2 bulbs in the freezer and 2 bulbs in the fresh food sections. It is unlikely that all the bulbs blew at the same time. When these lights went out, the water dispenser on the door stopped working at the same time.
  • slay11 May 18, 2010
    Sorry it took me so long to get back! I never really did remove anything. As I was attempting to remove the ice maker the lights and the water dispenser stopped working. I took the ice maker out with out unplugging it and noticed that the black wire going into the ice maker was out. I plugged it back in but still had the same problems. When you said that I had to connect the white/tan wire to neutral in the system; can you explain that a little better. (just a home owner)
    President:
  • 949 Answers
If all of the lights failed at the same time it would be most likely the door switch that has caused the problem.
It appears there are 2 bulbs in the freezer and 2 in the fresh food side, are all 4 out?
Posted on May 07, 2010
  • 2 more comments
  • Philip May 07, 2010
    Can you send me the complete model number from the tag? It should be located on the right top front wall of the fresh food section.
    Thanks, this will aid in tracing the wiring down.
  • Philip May 08, 2010
    There is no fuse but there could be a harness connection that needs to be bypassed with the ice maker out. Can you send me the complete model number from the tag on the refrigerator, that way I can pull up the wiring diagram for this particular model and advise you what to do. Thanks!
  • Philip May 10, 2010
    There is a common wire that connects to all these controls and lights you are having trouble with. It is the white/tan wire. I am guessing we need to connect that wire to neutral in the system. Do you still have the wiring from the parts you removed?
    What parts did you remove or unplug?
  • 213 Answers
Yes, it sounds like it is time for new bulbs.
If the fridge is still functioning but lights are out it is a simple fix.
If you can write back and leave me the exact model number of your fridge I can direct you to which bulb you will need to purchase.
  • 4,070 Answers
The door switch may not be opening all the way. It can get dirty and gummed up and not work. Try cleaning it and work it so that it comes out all the way. Will the lights come on when you pull it out all the way. If the switch is bad you can bypass the switch by touching the two wires together on the back of the switch and the light will come on.
  • Charles T Nevin
    Charles T Nevin May 07, 2010
    You will need to trace the wire checking for voltage till a voltmeter shows voltage. Try tracing it using the colors of the wires from the door switch to a wiring harness. There's a wiring harness under the fridge near the compressor.Here's a diagram of your unit.1
    http://www.appliancepartspros.com/partse...
    There's another wiring harness in the fridge. It's part 20 in the control diagram. The only thing common to the two lights might be the electronic control board. Part 6 in the control diagram.
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Describe your Superba Architect KSCS25INSS Side by Side Refrigerator Problem - fridge has power - lights on - but not cooling freezer or fridge - no noise coming from fridge -
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | KitchenAid Superba Architect KSCS25INSS...
Our Superba side by side has stopped cooling on both sides. We've cleaned the coils at the bottom of the fridge from the front panel. There continues to be a clicking sound, but the interior is not...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
How do you replace the water filter on a Kitchenaid Superba refrigerator. I can find the filter.
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Side by side, refrigerator side not cooling
Assuming that your fridge is set at max thermostat setting, and still it cools to 8 degrees only. It only mean
one thing, and that is have your refrigerant level check,
and have it loaded. E-mail to us your comments.
Oct 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge door is lower then freezer door
The #1 cause for this problem: The floor beneath the fridge is uneven, causing the refrigerator "box" to be out of square. Adjust the levelers on the fridge bottom to compensate for the uneven floor. That should do it.
May 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
Smoke from bottom of superba fridge
Dear customer,
Plz perform the following checks..
  • Remove spoiled food
  • Clean refrigerator interior with a solution of hot water and baking soda
  • Clean the door seals
  • Remove breaker strips and check for wet insulation
  • Please rate this,Thank u
    Dec 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
    KitchenAid Superba 48 Refrig
    hi, is the fridge cold enough.pull fridge from wall, remove back panel. clean all coils. this should solve the problem. thanks the appliance doc
    Oct 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
    KitchenAid Superba KSRS27CN Side by Side Refrigerator Logo
    209 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    vince
    geob91
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
