Question about Kitchen Ranges
Have a maytag dishwasher that got hit by lightning. It now shows all the lights on the front panel and makes a humming sound. Part2: Amana spacemaker microwave over the stove. same hit does not work at all nothing. Have any ideas?
  • 3,247 Answers
Make a claim on your house insurance.
Otherwise there is no limit to which you will keep going to find out what parts have had it.
A high voltage can damage almost everything, including the coils inside power supply transformers and motors.
I would suggest you take these off from the mains supply as you do not want to cause a short circuit and also electrocution.
Posted on May 07, 2010
Why does my amana front load washer hums and has a red blinking door locked light when I plug it in
The humming is coming from the motor. Sounds like the unit has overheated or sensed an electrical failure. The light indicates the same. It's either the door lock, iser interface or motor board. Call a qualified professional to fix this.
Nov 03, 2014 | Amana 3.5 cu. ft. Front Load Washer
When I plug my amana front load washer in it hums and wont start the only light that comes on is the door lock light and its blinking
well a hum usually is not a good sign, do u smell anything when it hums? sounds like a bad motor or bad motor windings to be precise.
Nov 03, 2014 | Amana Front Load Washing Machine Washer...
Maytag front-loading washer - all lights on indicator panel stay lit unless it is unpluged
1) Change the defective board, and call to the factory for exchange board return.
God bless you
Jun 18, 2012 | Maytag Washing Machines
My Maytag Epic Z washer stop in mid cycle then locked the door, we unlock the door via holding the cycle signal button down for 3 seconds, now we can open the door, close it, power up, start a cycle, but...
The low humming sound is from the pump. Remove the 3 screws on the bottom panel and remove it to check the pump filter. Here is a video for the "Duet Sport" washer. This washer is about the same. This video will show you the process and in this video the problem was similar to yours.
Happy Holidays The FixYa Team
Dec 19, 2010 | Maytag MHWZ600TB Front Load Washer
When a setting is chosen it makes a humming sound and stops water does not run or drain.
Hello & Welcome to FixYa
If the hum sound is coming from the bottom panel then it is the moto that has gone bad and needs replacement. However, if you hear the sound from the control then it can be due to a bad relay in the control and it is recommended to replace the control completely. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | Maytag MDB7100AWB Dishwasher
I have a Maytag MDB4651AWW3 dishwasher that stops during cycle
is it making a humming sound ,then the pump is blocked see if any thing is stuck under spray arm, worst could be is the motor unplug before working on it. thanks
Dec 01, 2009 | Maytag 24 in. MDBH950AWS Built-in...
LEA30AW makes a humming sound when i hit start,
motor is most likely bad shorting out in the windings
Jun 26, 2009 | Amana NDE2335AY Electric Dryer
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Kitchen Ranges Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
