Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Won't stand up or pick up
Wont lock in standing position and it is not picking anything up in the canister
  • 8,404 Answers
You probably have a clog in the dirt path ...
Posted on May 07, 2010
Dyson 18 wont stand
check this video out
Dec 03, 2012 | Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
DYSON WONT PICK UP
It sounds like there's something wrong with the changeover valve. This determines whether the airflow is directed to the cleanerhead or the wand and I think also provides the resistance to keep it upright. It's the bit above the right wheel as you stand behind it so try taking the inspection cover out and have a close look in that are for something wrong.
Sep 03, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson suction problem
I'm sorry to hear you're having difficulties with your Dyson. If the cleaner won't pick up via the cleaner head and will not stand upright, the valve carriage needs realigning. This is simple to do - please follow the steps shown in the video below.
This should resolve the issue, but for any further assistance or advice with your machine, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Dec 22, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson wont staND UPRIGHT
Hi its Darran at Dyson.
So that we can help resolve this, please call our Helpline on 0800 298 0298. One of our advisors can through some simple checks with you which will hopefully resolve the problem.
We look forward to hearing from you.
Kind regards
Darran
Dyson Customer Service
Mar 10, 2010 | Dyson DC25 All Floors Bagless Upright...
I have the bissell pet vacuum and it wont **** up anything I cleaned everything and it still wont pick up
It could be the belt. It the belt is worn or stretched it won't pick up the way it should. I would try changing the belt if you haven't recently. You can get the belts you need and the manual here:
Bissell Lift-Off Belt and Manual
Nov 14, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Dyson won't pick up heavier particles -
check the hose line from the base to inlet of the canister, there may be a blockage, like hair or plastic (i had a lego block and hair)
clear obstruction, and check the belt.
hope this works !
Jan 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson 07 won't stand up
I talked to Dyson support (they are open 6 days a week, try them if you're stuck)
Turn the vacum on it's side. Look on the side that has Bare floor/carpet control. There is a hose with two yellow buttons. Detach the hose. On the square side, look for a black button. Depress the button, then release. On the square side, slide the square up until it locks in place.
Now try to see if it will go upright (it should)
Finally, re-attach the hose.
Apr 18, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
126 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
