Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Projection tv the TV is a RCA 52inc HD projection TV it makes a wired beeping sound when the power is turned on it shows no pitcher and shuts of I opened it up and the wires that run along the screen all connected to a clip that looked like something was missing a tag on the wire says j conv sens
    Genius:
  • 1,030 Answers
Chirrping.....is indication of shutdown issue first thing to chech is make sure that the flat ribbion cables foint from the green board over to the power board are in place...this set shuts down for many reasons.. the most likely in your case would probalbkly be a blown horizontal output transistor. which could also mean a blown flyback transformer. a technician can replace these ..typical repair cost is about 100 to 300 dollars.
Posted on Mar 27, 2008
Tv wont turn on ? makes a noise but dosent come on and no burnt boards
I have a 52inc RCA t.v the t.v light turn on then turns off 3 time
Mar 01, 2010 | RCA P52926 52" Rear Projection Television
The TV tries to turn on three times, at each point making a loud high pitch beeping noise, and then shuts off. It is a HD projection TV, bought about 4 years ago.
Ur high voltage is dead,the FBT.The flyback transformer is dead.The big black block of plastic with a wire with cap hook up to ur CRT(tv tube).Might
also ur DM power board,have burns capacitors,check for puff ups capacitors must also be replace as rebuild board.U know how to solder right?Tries thes websites for parts.Tv Repair World.com Shopjimmy.com Partstore.com or Ebay.com.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
How to adjust pitcher size
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
May 25, 2009 | RCA R52WH76 Television
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
RCA P46920 TV will not turn on, it makes a beeping noise.
Shorted horizontial output transistor q14401 -I think- and bad flyback transformer(high voltage transformer).The noise is the power supply starting and shutting down very quickly because of the shorted transistor.Very common problem,but some of the flybacks are no longer available from RCA.Sometimes you can use generic but questionable life on some of these.
Jan 11, 2009 | RCA P46921 46" Rear Projection Television
Tv shuts off after awhile
DEAR fleming_pj
OPEN YOUR TV AND TRY TO RESOLDER ANY LOOSE CONTACT.
OR CHECK POWER SUPPLY UNIT .IT COULD FIX YOUR PROBLEM.
OK
Nov 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
Sounds like a bad flyback transformer . Whats the model # . These are common problems with those sets . Does it click then clicks right back off ? If so this is your problem . good luck
Jan 17, 2008 | RCA F27242GY 27" TV
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
