Tv staying on standby remote and side buttons nt working
  • 160 Answers
Unplug the tv for 1 minute, plug it back in this works 1% of the time. If the tv still does not turn on and the menu doesn't come up then the tv will need to be serviced.
Posted on May 07, 2010
HL32V86 Hisense 32' stuck on standby wont turn on it seems screen stay black
Call the HiSense tech dept. You can find the number on line and they will tell you how to fix it or you can try using the remote and go to settings and see if you can fix it that way. Also the manual for this tv should be available online as well.
Jan 03, 2015 | Hisense Televison & Video
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Mar 26, 2014 | Televison & Video
Schamthmsch
Hi.
If you have no picture, no sound and the TV stays in standby it is not the remote sensor. That is the TV in protect mode (forced standby). The TV goes in forced standby when an internal problem is detected. Most Sony have buttons on the TV set. If problem is the IR sensor the TV Twill wake up if you press the channel buttons on the set. Try disconnecting power cord for ten minutes. If that does not work call the Sony support number listed in your user guide.
Regards.
Ginko
Dec 15, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Why does'nt my vizio tv works with universal remotes
U follow the universal tv remote operation of manual book directions correctly?Yes,have u tries all those tv universal codes that was given to u for ur tv model and make?Yes.Than the tv maual IR sensor board on the tv could be dead,tries all those manual buttons on the tv side bazel frame,if all of it tv manual buttons work,properly the universal tv remote to complicated for u to operate.Return the thing.Try website like Remote.com to buy the tv original remote,than u don't ever care about universal codes ever again.
Jul 12, 2011 | Vizio L37 Television
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
TV doesn't turn on
I have a Mintek DTV265 which is almost the same TV the red light don't blink it stays on as long as the Power button is on. Try turning on the TV by pressing any of the buttons on the side of the TV Channel up or down, Volume up or down , or source. If it comes on then your TV is alright. I had one of them jumbo universal remote controls and it actually had a code that worked on my TV.
Mar 02, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Televison & Video
Hitachi CLE984
The code you need is 0145
Jul 01, 2008 | Hitachi CLU-5713TSI Remote Control
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
