My washing machine water is getting drained as soon as i connect it to the water source.
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that I wrote about the problem you are having with your washing machine...
Water will not stay in Washing Machine
http://www.fixya.com/support/r4696322-water_will_not_stay_in_washing_machine
heatman101
Posted on May 07, 2010
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Drain valve orientation
You have got the valve in back to to front.
you would get fault code 51 soon having it like that.
(00110011) Diverter Valve Fault
The motor controller has registered a drop in water level in the recirculation phase of the wash cycle. Water is being drained instead of recirculated.
Primary Source:
Action:
Diverter valve.
Remove the diverter valve and check for blockages as well as checking that the hinge mechanism on the valve hasn't broken. Remove the hinge from the solenoid and check that the flap is free to move. Check that water hasn't been sprayed onto the valve from an external source and caused the solenoid to blow.
Secondary Source: Motor Control Module.
Action: Turn the power off at the machine but leave the power on at the wall,
then measure the voltage across the terminals of the wax actuator. If a reading of 230V is achieved, the motor controller has failed due to a valve fault and both will need to be replaced.
Apr 16, 2013 | Fisher and Paykel IWL12 Top Load Washer
My Danby washer always drain the water when it fill the water up on the 3 and 4 water level setting. So I can't wash clothing at all. Hope get answer soon.
The answer is the drain hose. It must be routed higher than the machine or water will always drain. There is no actual drain valve.
Oct 07, 2010 | Danby DWM99W Top Load Washer
Washing Machine on the blink mainly due to no spin/drain cycle wo
check your drain filter, get a wet vac and vacuum the water out, then open the drain plug at bottom and try to vacuum the drain to clear out debris......then turn on and test washer if it fills and drains if it fills with water and doesn't drain then your drain pump is defective........get your model number and source for a pump motor.................................
if it doesn't fill with water then your water fill switch is defective...............source for parts..............
if this helps out anyone a feed back would be good..........
Apr 16, 2010 | Miele Novotronic W1918A Front Load Washer
Water gets drained immediately without washing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jun 04, 2009 | Samsung WF203ANW Front Load Washer
4E showing on Samsung Washing Machine
Apr 06, 2009 | Samsung WF337AAL Front Load Washer
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water leak
Did you check the drain hose?
Jun 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
