Question about RCA 27R410T 27" TV
Stuck on 1 channel
RCA 36 " Chassis # CTC203CX1. Stuck on ABC. TV worked perfectly until we moved. Cable company checked out says it is tuner problem
  • berniecost May 08, 2010
    still looking for help
  • 160 Answers
Get a cable box from the cable company it will be cheaper than repairing the tuner. Then you use the tuner from the cable box instead.
Posted on May 07, 2010
I have my rca model f36665 hooked up strait from the wall to the tv and I can't get it to find the channels. do I have to have a cable box?
First if cable I presume you have entered the menu and selected cable.
Another possible reason is the tuner/s in this set are bad---hook a DVD or something to one of the rear inputs and see if set works.
If set works that way and tuner turns out to be bad you can with a box with av cable out connections on back just go into a rear input and bypass the tuner--leave set on that input and change channels with the box.
Let me know if you have questions and what you find---usually on this set if no signal---"unusable signal" will appear on screen if no signal.
Mar 20, 2012 | RCA F36665 36" TV
RCA F36715 36" TV received this tv used from a friend. we do not have original remote so we use a generic universal remote. tv works fine, but we cannot get the Guide Plus+ to work. we went through the...
You're cable company may have quit using TV Guide info from "TV Guide", because they want you to get their box for this info, or to save expense. It happened here in Michigan about a year ago. If you have local ABC, NBC, and PBS stations, you can get this info downloaded nightly through an external "over-the-air" antenna.-- assuming you're in the U.S.
May 05, 2010 | RCA F36715 36" TV
QUAM TUNER
Doubt it. We ran HD through our small CATV system using consumer grade modulators but could only get them on the AIR frequencies, as we had very limited bandwidth as we had to carry 64 analog channels plus digital HITS packages for our Motorola DSxxx series boxes. Try plugging the CATV feed into the ANT input and do an autoprogram, or tell the tv to look on the AIR frequencies when it asks if you have CATV or AIR. Worth a shot though.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken cable hook up
sometimes if the tuner is not damaged then a technician can put it back on... the other option is to tune the channel through a vcr.. essentally bypassing the tv tuner and useing vcr tuner. hook the cable to vcr then using rca jacks yellow red and white connect it to you tv(if it has rca jacks ...most have them these days.. sometimes on front and sometime on back or even on the side.. tune your tv to that input(video 1 or something like that.. then using your vcr remote change channel...its not a perfect solution but it will save you the 130 buck most charge to repair that connector
May 01, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
TV (RCA model F32705) stuck on one channel
go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
Jan 04, 2008 | RCA P46924 46" Rear Projection Television
RCA F27664 27" TV Problem: HELP
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Channel reception lost if tuner socket moved
Dry joints on IC522, IC521 and IC541 (located in the big heatsink about middle of the main pcb)
Nov 24, 2007 | RCA F27664 27" TV
Have cable.........but not working
The GE (actually RCA) 31GT659 has the notorious CTC187 chassis. This chassis developes cracks in the solder joints on the shields around the tuner and microprocessor, and can mess up the settings stored in the EPROM IC. This could result in channels going snowy, vertical collapse, loss of sound and/or total shut-down. The set should be resoldered and reprogrammed by someone experienced with this RCA chassis.
Jun 22, 2007 | GE 31GT659 31" TV
Lost channels 2 through 52
I think the low band (Channel 2-6)in your tuner is not working. This could be in the tuner itself or in the band switching circuits. Possibly she deleted the low channels or locked them out. Stargazer
Jun 14, 2007 | RCA F32632SB 32" TV
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
Apr 25, 2007 | RCA F32705 32" TV
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
RCA 27R410T 27" TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
