Question about RCA D52130 52" Rear Projection Television
RCA D52130 CHASSIS CTC211A PROBLEM
MY RCA HDTV D52130 BUILT IN JUNE 2002 JUST TURNED OFF A FEW DAYS AGO WHILE I WAS WATCHING A PROGRAM, THE POWER LIGHT DOES NOT COME ON. I HAVE UNPLUGGED IT, CHECKED THE POWER OUTLET, TRIED TO TURN IT ON MANUALLY NOTHING WORKS. ANY SUGGESTIONS?
  • 4 more comments
  • WhitneyR Jun 02, 2008
    Hi, We are having the same problem w/ RCA model D52130. My husband was watching Saturday and the power just shut off. There was no click, just complete loss of power. Where exactly is the fuse located?
    Thank you!
  • a118blocc Aug 08, 2008
    the tv just turned off and when i try to turn it back on it trys to come on the green light comes on and blinkes and then the green turns off but the tv does not come on at all
  • Anonymous Aug 18, 2008
    I believe the set has a power spike circuit that shuts it off if detected for 1 minute,it not enough to trip surge protector but could damage set.Should be able to turn on after 1 minute. I got a power conditioner and now never happens.
  • Anonymous Oct 16, 2008
    I have RCA Model #D52130 Chassis #CTCZ11A it is an 2001 52"
    projection TV. I hit power switch the green light comes on and then off
    then blinks 3 times and then nothing. The TV does not come on at all. What do I look for or how can I tell if a
    part is bad?
  • yram527 Dec 19, 2008
    I have the same problem, Where is the fuse box located?
  • cjking12 Jan 03, 2009
    Hi, I also had the same problem. My husband was watching and the power too just shut off and does not come back on at all. What should I do?
    thanks
  • RCA Master
  • 8,617 Answers
Do you hear a click when you try to power it up? If no you may have a blown fuse. But if the fuse is blown chances are a short has caused that condition. Check the fuse to see if its blown and let me know and I will try to help you out with it.
Posted on Mar 27, 2008
SOURCE:
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Will not turn on
if it is the chassis im think it is you will have to take the back off looking at the chassis the very front right corner there is a board apporx. 6in. long 2,3 in wide look at the fuse if it's blown take the small board out make sure set is unplugged it just clips in around the edges with plastic clips there are a set of diodes toward the opposite end they make check shorted if so replace there is a part number on the side of the diodes call some shops or go to fry's online maybe
if it is not blown there are 2 wire cable that comes from that board all the way up to another board called the deflection but the easiest way to check it is your board at eye level to the right those wires go there also a brown and green or blue wire to the top left hand corner of that board check with a volt meter on D/C setting for 300 to 340 volts if you have those volteges you could have a problem on the deflection board
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52130 herd pop tv went dead
dear friend your tv has a defective fly-back transformer 99 times out of 100 that is your problem.
get the model number and call your local electronics parts distribuitor to see if they have it, if not call tritronics 1800-638-3328 they probably have it and is not too expensive.less than $25.00.now when you get here is the million dollar question can you do it yourself? if you can't call the repairman and by having the fly-back that will decrese the cost of the repair, is just the labor.
good luck
[email protected]
Sep 02, 2008 | RCA D52130 52" Rear Projection Television
I have sound but no picture?
i setup a remote code on the remote so the tv goes on /off and the volume but no picture on screen how when i put the dvd player i can see the movie but noy regular tv please help
May 08, 2008 | RCA D52130 52" Rear Projection Television
Is Repair worth trying?
its smart to try to DIY if its only the sound that was lost.
but be very careful as such appliance have very intricate design. always be careful.
you can start by troiubleshooting the speaker itself then work down going to the wires of the speakers then the audio chip.
if you still have some questions, just post them here.
Mar 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52130
the fuse should be located right near where the power cord plugs into the chassis
Mar 28, 2008 | RCA D52130 52" Rear Projection Television
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52130 52" Rear Projection Television Logo
492 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
