Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
When turned on the pump operates as normal, stops then starts aga
When functioning normally, the dish-washer first operates the pump for a short time, this stops and water enters. Now, the pump operates, stops, no sound of water entering, then pump starts again and on & on!
There is water pressure up to the machine. Sounds as if the central controller does not get a signal that there is pressure. Inlet valve problem? The LCD screen has not worked for a long time, except on drying cycle when it suddenly comes alive! Suspect damp air is making a contact to enliven the screen, but where????
Terry P
  • LG Master
  • 19,396 Answers
Hi.
Regarding the fill problem, the electronic control board rarely fails in the way you described.
When filling stops beforetime in the cycle, this is caused by the water level sensing device.
Before replacing the timer board (that is probably faulty), the water level switch must be tested, disconnecting power and wiiring and reading Ohms to ensure that the switch is opening and closing, or by jumping the switch and controlling the cycle manually to prevent overfill.
To get parts and schematics see: Where do I find parts and diagrams?
Regards.
Posted on May 07, 2010
My washer wont spin out
Usually what happens here is that the pump to expel the water is not functioning, the normal problem here is a coin or hair grip gets lodged in the pump and stops the impeller from turning, generally the pump can be removed and opened up to remove the offending article and allow the impeller to operate again, once cleared of obstruction reassemble the pump and refit it. ( be aware, as the machine is still full of water, when you remove the pump the water will flood out so you need plenty of towels so soak up the water that spills.
Aug 05, 2016 | Samsung WF337AA Front Load Washer
Where is the fuel pump relay and how can e serviced?
Description
*: ECM determines the start signal status by the signals of engine speed and battery voltage.
The ECM activates the fuel pump for several seconds after the ignition switch is turned ON to improve engine start ability. If the ECM receives a engine speed signal from the camshaft position sensor (PHASE), it knows that the engine is rotating, and causes the pump to operate. If the engine speed signal is not received when the ignition switch is ON, the engine stalls. The ECM stops pump operation and prevents battery discharging, thereby improving safety. The ECM does not directly drive the fuel pump. It controls the ON/OFF fuel pump relay, which in turn controls the fuel pump.
Component Function Check
1.CHECK FUEL PUMP FUNCTION
1. Turn ignition switch ON.
2. Pinch fuel feed hose (2) with two fingers.
1 : Air cleaner assembly
Fuel pressure pulsation should be felt on the fuel feed hose for 1 second after ignition switch is turned ON.
Is the inspection result normal? YES >> INSPECTION END
NO >> EC-466, "Diagnosis Procedure".
Diagnosis Procedure
1.CHECK FUEL PUMP POWER SUPPLY CIRCUIT-I
1. Turn ignition switch OFF.
2. Disconnect ECM harness connector.
3. Turn ignition switch ON.
4. Check the voltage between ECM harness connector and ground.
Is the inspection result normal? YES >> GO TO 4.
NO >> GO TO 2.
2.CHECK FUEL PUMP POWER SUPPLY CIRCUIT-II
2. Disconnect IDPDM E/R harness connector F10.
3. Check the continuity between IPDM E/R harness connector and ECM harness connector.
Is the inspection result normal? YES >> GO TO 3.
NO >> Repair open circuit or short to ground or short to power in harness or connectors.
3.CHECK CONDENSER-1 POWER SUPPLY CIRCUIT-I
1. Reconnect all harness connectors disconnected.
2. Disconnect condenser-1 harness connector.
4. Check the voltage between condenser-1 harness connector and ground.
Is the inspection result normal? YES >> GO TO 5.
NO >> GO TO 4.
4.CHECK 15A FUSE
2. Disconnect 15A fuse (No. 32) from IPDM E/R.
3. Check 15A fuse.
Is the inspection result normal? YES >> GO TO 6.
NO >> Replace fuse.
5.CHECK CONDENSER-1 POWER SUPPLY CIRCUIT-II
1. Disconnect IPDM E/R harness connector E18.
2. Check the continuity between IPDM E/R harness connector and condenser-1 harness connector.
3. Also check harness for short to ground and short to power.
Is the inspection result normal? YES >> GO TO 13.
NO >> GO TO 7.
6.DETECT MALFUNCTIONING PART
Check the following.
??? Harness connectors E29, B10
??? IPDM E/R connector F10
??? Harness for open or short between IPDM E/R and condenser-I
>> Repair open circuit or short to power in harness or connectors.
7.CHECK CONDENSER GROUND CIRCUIT
2. Disconnect dropping resistor harness connector.
3. Check the continuity between condenser-I harness connector and ground.
4. Also check harness for short to ground and short to power.
Is the inspection result normal? YES >> GO TO 8.
NO >> Repair open circuit or short to power in harness or connectors.
8.CHECK CONDENSER-1
Refer to EC-469, "Component Inspection (Condenser-1)".
Is the inspection result normal? YES >> GO TO 9.
NO >> Replace condenser-1.
9.CHECK FUEL PUMP POWER SUPPLY CIRCUIT-III
1. Disconnect ???fuel level sensor unit and fuel pump??? harness connector.
2. Check the continuity between IPDM E/R harness connector and ???fuel level sensor unit and fuel pump??? and ground.
Is the inspection result normal? YES >> GO TO 11.
NO >> GO TO 10.
10.DETECT MALFUNCTIONING PART
??? Harness connector E29, B10
??? Harness for open or short between ???fuel level sensor unit and fuel pump??? and IPDM E/R
??? Harness for open or short between ???fuel level sensor unit and fuel pump??? and ground
11.CHECK FUEL PUMP GROUND CIRCUIT
1. Check the continuity between ???fuel level sensor unit and fuel pump??? and ground.
2. Also heck harness for short to power.
Is the inspection result normal? YES >> GO TO 12.
12.CHECK FUEL PUMP
Refer to EC-469, "Component Inspection (Fuel Pump)".
NO >> Replace fuel pump.
13.CHECK INTERMITTENT INCIDENT
Refer to GI-42, "Intermittent Incident".
Is the inspection result normal? YES >> Replace IPDM E/R.
NO >> Repair or replace harness or connectors.
1.CHECK FUEL PUMP
2. Disconnect ???fuel level sensor unit and fuel pump??? harness connector.
3. Check resistance between ???fuel level sensor unit and fuel pump??? terminals as follows.
NO >> Replace ???fuel level sensor unit and fuel pump???.
1.CHECK CONDENSER
3. Check resistance between condenser-1 terminals as follows.
Fuel injector Description The fuel injector is a small, precise solenoid valve. When the ECM supplies a ground to the fuel injector circuit, the coil in the fuel injector is energized. The energized coil pulls ...
Ignition signal Description The ignition signal from the ECM is sent to and amplified by the power transistor. The power transistor turns ON and OFF the ignition coil primary circuit. This ON/OFF operation induc ...
Other materials: Heater & cooling unit assembly
Removal and Installation COMPONENTS 1. Steering member 2. Heater and cooling unit 3. Blower unit REMOVAL 1. Discharge the refrigerant from the A/C system. Refer to HA-24, "HFC-134a (R-134a) Service Procedure". 2. Drain the engine coolant from the cooling system. Refer to CO-1 ...
On-vehicle repair
WHEEL HUB Removal and Installation 1. Knuckle 2. Baffle plate 3. Wheel hub assembly 4. Brake rotor 5. Wheel nut 6. Anchor block 7. ABS sensor 8. Parking brake cable A. Refer to PB-6, "PEDAL TYPE : Exploded View" (Pedal type), PB-7, "LEVER TYPE : Exploded View" (Leve ...
P0011, P0021 IVT control
DTC Logic DTC DETECTION LOGIC NOTE: If DTC P0011 or P0021 is displayed with DTC P0075 or P0081, first perform the trouble diagnosis for DTC P0075, P0081. Refer to EC-1191, "DTC Logic". DTC CONFIRMATION PROCEDURE 1.PRECONDITIONING If DTC Confirmation Procedure has been previousl ...
Mar 02, 2016 | Cars & Trucks
My Neff dish washer runs for about 30 sec to a 1 min then just turns it self off the water pump sucks water in ok and the pump takes the water out ok ? help
that sounds like normal operation......the pump takes out remaining water then stops and lets in new hot water.
Oct 26, 2014 | Neff Dishwashers
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
The clean light is blinking and I can not start a new load. I have cleaned out the washer and loaded dirty dishes and it will not start
Press the heated dry then normal wash buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Please let me know if these does not resolve the problem.
Nov 30, 2009 | Refrigerators
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Neptune front load washer stopped due to out of balance load. Now wont start turning, has a humming sound
went through the test program in the installation/service manual, which was taped to the back of the washer. It indicated that the drain .pump was not operating. Checked voltage to pump- OK at 116V. Pump was stalled and getting warm. Dismantled motor from pump housing and found impeller was stalled by a broken toothpick. Reassembled and washer now operating normally.
Jul 05, 2008 | Washing Machines
Goes through cycles but does not clean dishes
Do you know if the washing arms are turning. Normally after the machine fills up the main pump begins and the washer sounds like it is washing dishes. If you carefully open the washer at this point (just a little) it will be eveident that water has been sprayed around inside as it will be dripping everywhere. If not you pump hasn't activated. This does not mean you pump is broken however it could be the pressure level switch sticking and not completing the circuit that starts the pump.
Apr 29, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
82 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
