Question about Microsoft Computers & Internet
How to get MsgBox function on Form - Microsoft Computers & Internet
  • 30 Answers
This question is way too generic but in Visual Basic 6 for example you would just call the function from a method such as:
sub buttonclick()
msgbox("Hello World")
end sub
Posted on May 23, 2010
18. A palindrome is a string that reads the same
here is a little vbscript sample str=InputBox("Type String To check For palindrome","")
strR=StrReverse(str)
half=Int(Len(str)/2)
If Left(str,half)=Left(strR,half) Then
    MsgBox ("It's a palindrome string")
Else
    MsgBox ("It's not a palindrome string")
End If
Jun 05, 2010 | Computers & Internet
I want to use two independent Sub procedures: One to convert a temperature from Farenheit to Celsuis, and the other to convert a temperature from Celsuis to Farenheit
Save this as a vbscript (filename.vbs) and modify the language as needed. Should be pretty self explanatory let me know if that works.
Sub ConvertTemp()
temp = InputBox("Please enter the temperature in degrees F.", 1)
MsgBox "The temperature is " & Celsius(temp) & " degrees C."
End Sub
Function Celsius(fDegrees)
Celsius = (fDegrees - 32) * 5 / 9
End Function
Function Fahrenheit(cDegrees)
Fahrenehit = (cDegrees + 32) * 9/ 5
End Function
Apr 05, 2010 | Computers & Internet
Validating textbox, the textbox should be accept numbers only Im using a PL vb6.0
Put the following code to txtBox_BeforeUpdate function:
If IsNumeric(txtBox.Text)=false then msgbox "Numbers only"
Feb 14, 2010 | Computers & Internet
How to create an object of VSI-Fax like in winfax
For VB
Private Sub Form_Load()
Dim sendObject As Object
Dim ret As Integer
Set sendObject = CreateObject("Winfax.SDKSend")
ret = sendObject.SetSubject("TEST!!!")
If (ret = 1) Then
MsgBox ("SetSubject Failed")
End
End If
ret = sendObject.SetKeywords("Test")
If (ret = 1) Then
MsgBox ("SetKeywords Failed")
End
End If
ret = sendObject.SetResolution(0)
If (ret = 1) Then
MsgBox ("SetResolution Failed")
End
End If
ret = sendObject.SetQuickCover(1)
If (ret = 1) Then
MsgBox ("SetQuickCover Failed")
End
End If
ret = sendObject.SetCoverText("This is a Test.")
If (ret = 1) Then
MsgBox ("SetCOverText Failed")
End
End If
ret = sendObject.SetUseCover(1)
If (ret = 1) Then
MsgBox ("SetUseCover Failed")
End
End If
ret = sendObject.ShowCallProgress(1)
If (ret = 1) Then
MsgBox ("ShowCallProgress Failed")
End
End If
ret = sendObject.SetTo("Somebody")
If (ret = 1) Then
MsgBox ("SetTo Failed")
End
End If
ret = sendObject.SetNumber("#######") 'My fax number
If (ret = 1) Then
MsgBox ("SetNumber Failed")
End
End If
ret = sendObject.SetAreaCode("###") 'My area code
If (ret = 1) Then
MsgBox ("SetAreaCode Failed")
End
End If
ret = sendObject.SetPriority(1)
If (ret = 1) Then
MsgBox ("SetPriority Failed")
End
End If
ret = sendObject.AddRecipient()
If (ret = 1) Then
MsgBox ("AddRecipient Failed")
End
End If
ret = sendObject.LeaveRunning()
If (ret = 1) Then
MsgBox ("LeaveRunning Failed")
End
End If
ret = sendObject.GetRecipientCount() 'this shows 1
MsgBox ("Recipient Count: " & ret) 'recipient
ret = sendObject.Send(1)
If (ret = 1) Then
MsgBox ("Send Failed")
End
End If
End Sub
If u like that Appreciate me by giving vote.
And try to be little specific while u ask question, that means, if u want code on any object ask for which language u r in need of?
Oct 19, 2009 | Esker VSI-FAX 4.x (25301) for Unix
Accept x and y from user and calculate x raise to y
here is the solution;
solution 1 (need 3 text boxes, Namely text1, text2 & text3 & a command button. Put the code below in the button click event) Dim x, y As Integer x = Text1 y = Text2 Text3 = x ^ y
solution 2 (put the code either in form load event or button click event)
Dim X, Y As Integer X = InputBox("Enter X", "X ? ") Y = InputBox("Enter Y", "Y ? ") MsgBox "X^Y = " & X ^ Y
May 18, 2009 | Polar Electro Wearlink Coded Watch
An example of visual basic program
Visual Basic (VB) is the thrid generation event-driven programming language and integrated development enviorment (IDE) from Microsoft for its COMprogramming model. VB is also considered a relatively easy to learn anduse programming language, because of its graphical development featuresand BASIC heritage.
Here is an example of a code that displays a message box "Hello, World!"
as the program runs:
Private
Sub Form_Load()
MsgBox "Hello, World!"
End Sub
simply making duplicated lines of text and changing the words in the
speech marks can draw a different text and ammounts.
For example:
Private
Sub Form_Load()
MsgBox "Welcome, blue_skies61!"
MsgBox "My name is Siwek06!"
End Sub
you can also bold the text by puting this line before a text:
Sub SetFontBold()
Overall i think this is a easy language to learn.
Go on to microsoft.com help center, or the forums to learn more.
Feb 23, 2009 | Visual Land V-Touch Digital Media Player
How do you check a Text File is empty or not in vb6.0
Here is a script that shows you how to do this
On Error Resume Next
Dim fso, s
Set fso = CreateObject("Scripting.FileSystemObject")
Const ForReading = 1
Set ts = fso.OpenTextFile("c:\testfile.txt", ForReading)
s = ts.ReadAll
ts.Close
if len(s) = 0 then
msgbox "File is Empty"
else
msgbox len(s) & " " & s
end if
Nov 07, 2008 | Computers & Internet
Vb6 source code is not compiling.
What the heck are you compiling it with that doesn't give a line number for that error? Pay attention to the titles of messageboxes! Perhaps noting what lines you changed from the original will give a clue to narrow it down, but I expect you addressed an object with a property (object.property) in a context that can't be expected to generate or use that property as you gave it. Moreover there are spaces in object names, it seems....
Apr 13, 2008 | Computers & Internet
Access 2003 HELP PLEASE!
Sharon King:
Did you get this problem solved? I realize it is quite old, but I am willing to help if it is not solved. If it is, I would be interested to know what happened...
smartsolve
Feb 18, 2008 | Microsoft Office Access 2003 (077-02871)...
Computers & Internet Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
