Question about Home
Shower is not emptying very quickly. should it go to mains drainage or just to a drain
  • 159 Answers
Goes to Main drainage. Pour bleach or any drain cleaner down plughole with very Hot hot water will fix
Posted on May 08, 2010
How do I get to the p-trap under the shower floor in my Jayco 2007
From underneath or through an adjoining storage compartment depending on how it was configured. You may be able to rejoin the pipe by putting a broom handle through the drainage pipe and using it like a lever while you repair the drain.
May 26, 2015 | Plumbing
How do I make the sanilo empty the shower faster?
no way to speed up the draining . just slow down the input if too much
Feb 19, 2015 | Home
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
http://s3.amazonaws.com/szmanuals/b0348062b23e23cd40550b61e1dc5f43
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
Why is there water on my furnace when the a/c is running?
Condensate normally drains into a pan that either empties into a floor drain by gravity or empties into a pump inlet for discharge outside. The drain pan may be clogged, preventing it from emptying or, more likely, the drain pan is leaking condensate.
Jun 28, 2014 | Heating & Cooling
What would be the minimum pipe size for drainage from floor trap taking flow from shower and from vanity bowl? What is the minimum pipe size for drainage shower? Ditto from vanity bowl?
That depends on the flow rate you want and your local building codes. When I rebuilt my bath, I had poor flow from both the sink and shower. My sink had 1 1/2 inch pipe and my bath had 2 inch. I replaced the entire sink run with 2 inch after the P trap and the shower I used 2 1/2 inch - problem solved!!
Nov 15, 2010 | Plumbing
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
I am instaling a shower under my house and i was hoping to get away with not cutting into the concrete for the drainage, is it possible to raise the shower bottom a foot of the ground for the drainage, and...
Yes, you can raise to avoid the cut by raising shower as long as gravity drain can occur, i.e. you can drain the shower to connect to existing drain lines. Definately put the s-trap in, if no trap then plumbing gas comes back and shower will smell. Remember to put in a plumbing vent or tie in to existing vent.
Mar 19, 2010 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
I have a septic tank, but I really don't think that it's the problem. Everytime we take a shower, wash clothes, or run water for a few minutes the house starts to stink bad. There is no drainage problem...
hi
just trying some inputs
is your septic tank designed have an outlet pipe or out put air ventalation for the air that accumulated inside your tank released outside your tank try to check it of its clog
hope its help
Jul 09, 2009 | Plumbing
My hotpoint ffa74 fridge freezer drainage hole in fridge compartment never drains away the water. have emptied and defrosted but made no difference
Defrost the fridge. I recommend at least 24 hour period, it's normally quicker. After it has defrosted empty the tray at the back by simply unscrewing the tray and removing the little black rubber tube. To test that it has totally defrosted pour coke down the drain inside the fridge with the tray back in, this should filter into the tray. Clean the tray again and insert black rubber tube and tighten screws again, job done.
I had the same problem but it was all sorted within 16 hours as it defrosts quickly.
May 02, 2008 | Refrigerators
Home Logo
37 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
