Question about ViewSonic N3251w 32 in. LCD HDTV
Viewsonic n3251w went bezerk!
I was playing with my ps3 when out of nowhere the sound started to go up until it reached max. Then i tried lowering it with the remote and still went up. I took the batteries out of the remote to check if it was a bad contact in the remote and it would still do the same thing. I turned it off and would not come back on. I unplugged it and replugged it. it came back on but started that volume frenzy again. Where should I start looking?
    Guru:
  • 416 Answers
The button board or the IR board in the TV. A stuck button can cause some strange behavior. Typically, the TV has 3 control lines: POWER BUTTON, FUNCTION BUTTONS, IR (Remote). Try disconnecting the button board, it should have a connector right on the board. If that fixes it, you can leave it that way or try to find a replacement board (not sure where you should look). If it's the IR board and the button board is daisy-chained through it, you will need to either replace it or repair it. Most often the little receiver is bad when there is a problem with this type of board. You may be able to find a Receiver IC, but just know that it has to match the TV. I hope this was helpful and points you toward your destination. Best wishes.
Posted on May 07, 2010
Testimonial: "I disconnected the button board and tried the tv set so far so good. i'll use it for a while like that to see if anything else happens. Thanks!"
Sound issues when connected to PS3 with HDMI
I don't think you can hook a PS3 to 350W projector. You are maxing out the PS3 output. Good luck with it
May 03, 2014 | Optoma PRO350W Projector
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
My PS3 was playing great the other night (playing Modern Warfare) and out of nowhere it turned off on me with the red light blinking. I tried to turn it on and the red light went solid like it normally...
It sounds like you have the dreaded Ylod its a common issue, Try resetting the system which works once in every systems,
If that does not work then you will most likely need to replace the Power supply, if your uncomfortable opening it,
Look on craigslist to see if there are any local repair shops in your area, that is uaually a 60 dollar fix on average but depends where you live.
Sep 10, 2010 | Sony Playstation 3 (PS3) Console
I was playing a game and my PS3 froze up. I could not power down from the remote, so I pushed the power button on the front of the console. After a minute I turned the console back on. The blue&green...
Try this : When you put your ps3 on, hold the power button on the front of the console until it beeps 2 times, then the screen should start flashin and after that u'll get the chance to choose what resolution u want and so on.
When you hold down the power button like this, the screen goes back to default. Should fix your problem!
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont play movies
Sounds Like your blu-ray drive is going bad. if you still have warranty play movies until it breaks and get a new one
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
No sounds when i play psp games
1) Try plugging in and out the headphone jack with headphones and see if the speakers turn on
2) Make sure the volume button + is pushed until you reach max volume.
3) You may have a broken speaker from dropping the PSP which has occurred to me before.
Jan 31, 2009 | Sony PlayStation Portable (PSP) Console
Freezes?
try this as it is a wide spead problem with lots of ps3s
Please run through the following, go through in order.
1) Delete the game's install data. This is done via the PS3 options. Scroll along the cross media bar until you reach the 'Game' tab, now scroll up / down the list until you reach the 'Game Data Utility' Enter this and locate the (GTA IV ) option or the game thats freezing option. Highlight this and press triangle once, from the menu select Delete. This will delete the game's install information.
2) Delete the game's save files. To delete any save files you will need to do the following. Scroll along the cross media bar until you reach the 'Game' tab, now scroll up / down the list until you reach the 'Save Data Utility' Enter this and locate the GTA IV / other game name option. Highlight this and press triangle once, and from the context menu select Delete.
3) Disable your Internet connectivity for the PS3. To do this scroll along the cross media bar until you reach the 'Settings' tab, now scroll up / down the list until you reach the 'Network Settings'. Now scroll down to the Internet connection option and press x, now select the disable option. Once this has been done unplug the ethernet cable if you are connecting to the Internet if using this.
4) Disable the console's information board. To do this scroll along the cross media bar until you reach the 'Network' tab, now scroll up / down the list until you reach the 'Information Board', highlight this and press triangle. From the menu select 'Do not display' Press X to confirm this.
5) Disable Media Server functionality. Scroll to Settings, now scroll up / down to 'Network Settings' select Media Server connection. Once this has been done press triangle and change the option Disabled.
6) Delete all of the system's Internet cache. To do this scroll along the cross media bar until you reach the 'Network' tab, now scroll up / down the list until you reach the 'Internet Browser', highlight this and press X. Once you browser opens press the triangle button once, from the new menu highlight the 'Tools' option and press X. Scroll down the menu until you reach 'Delete Cookies' and press X. Confirm the files deletion. Repeat this for 'Delete Cache'.
7 ) Turn off the PS3 screen saver. Use the cross media bar to scroll to 'Settings', select 'Display Settings'. Now highlight 'Screensaver' and set this to 'Do not use'.
8 ) Once this has been done, manually restart you PS3 by holding down the power button for 5 seconds it will beep once and then shut down. Release the power button and re-press it and hold for about 5 seconds. The system will then boot and reset all display settings. You will be prompted to reset your display settings to how you require them.
9) Once restarted please try the game again, you will be prompted to reinstall.
Once the game has started please turn off the following features:
1) The game's auto-save. Press Start, Game, and locate the Auto-save option. Turn this off.
2) Turn off the game's flicker filter. Press Start, Display and locate the Flicker Filter option. Turn this off.
3) Turn off the controller vibration feature. Press Start, Controls and locate the vibration option. Turn this off.
if this fails then you`ll need to call sony and i believe they charge for a fix...
Sep 26, 2008 | Sony Playstation 3 (PS3) Console
Play station 3 dvd remote pairing instructions.
OK I FIGURED IT OUT!!! First turn off the system(ps3) make sure that you take the batteries out of the remote. Then when you turn it back on go straight to system setting, setting accessories, setting blue tooth device. AND THEN IT WILL TELL YOU TO HOLD DOWN THE START AND ENTER BUTTON DOWN!. Don't forget to put the batteries back into the remote. It took like 3 seconds.
Jun 20, 2008 | Sony Blu-ray Remote for PlayStation 3
ViewSonic N3251w 32 in. LCD HDTV Logo
335 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
