Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
I have try all the configuration you can do on the
I have tried all the configuration you can do on the machine. Still I think it is to weak espresso. I decrease the water, increase the coffee dose and try do change the coffee grinder.
Still I don't have a strong cup of Espresso. What to do?
/Rickard from north of Sweden
  • 1,089 Answers
Hi
Check you grind. See if it is like grandulated sugar. If it is coarser than that, it might be you grinder has come apart. If not, it might be all you can get out of the machine.
Posted on May 07, 2010
Hi, can you adjust the portion size of beans ground per cup for a saeco rotel conforta automatic espresso machine. The coffew is coming out fine, but too weak.
In the waste basket you got a nice round coffee puck i think you need to ajust the grinder its not chopping fine enough press for a coffee and put the dial down 1 like if your at 6 put 5 remmember the coffe you grind will take 2 coffe to reach try a couple and if your satisfied good if not go down on more try again
Mar 29, 2015 | Saeco Coffee Makers & Espresso Machines
Weak coffee/water flows too fast
you need to take it to a service center as it is still under warranty they should be able to get it fixed for you
Jan 25, 2014 | Gaggia Baby Espresso Machine
My gaggia titanium is dispensing very weak coffee. No idea why. Have tried different beans. No change.
try a finer grind coffee , you cant use a "store" grind in a cappuccino machine it requires a much finer grind than that
Dec 07, 2011 | Gaggia Titanium Espresso Machine
GAGGIA TITANIUM........WEAK COFFEE
Try adjusting the grind finer, if that does not help then go to menu and make sure pre infusion is enabled.
Jan 19, 2010 | Gaggia Titanium Espresso Machine
Grinds too long coffee still weak
You can adjust the grind, finer will give you stronger coffee. Think water through sand vs. pebbles. There are also settings you can find in your owners manual for adjusting the length and strength of your "pull".
Try Julius Meinl espresso roast, it's dark, rich and sweet. Definitely my favortie.
Dec 24, 2009 | DeLonghi EAM3400 Espresso Machine
Water and frother are weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Dec 17, 2008 | Saeco Royal Digital Plus Coffee...
Pressure is weak.
I am a certified tech for laspaziale Are you thinking the pressure is low because the gauge on the front panel does not go all the way to the green ? many of them didn't right from the factory. the pressure is not adjustable and unless it is really low don't worry about it
Dec 14, 2008 | LaSpaziale S1 Vivaldi Espresso Machine
Coffee is weak / Is pump supposed to kick on and off during brewing or run steady
Aug 26, 2008 | Krups XP4030 Espresso Machine
Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Jul 16, 2008 | Gaggia Titanium Espresso Machine
The grounds are sloshy and the coffee is weak - I think that the coffee is leaking out as the hot water is being pumped through the ground beans
I think I have the answer to this: when mine started doing the same thing, I found that coffee grounds had accumulated and were blocking the seal of the water supply with the brew-group.
The Behind the brew-group is a clear tube with o-rings that slides into the brew group to supply water. One or both of these is clogged with accumulated coffee grounds. Try cleaning out both well.
-tony
Apr 28, 2008 | Saeco Easy Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
79 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
