Question about Konica Minolta Office Equipment & Supplies
Printer will not print says service call 17 Toner Pack
  • horse31 May 07, 2010
    I will call in help - the information is too difficult for me
  • 4,472 Answers
First off what is the make and the model of the printer? How long have you owned it and how long have you had this problem? Once I have more information I can assist you further.
Thank you,
lee
Posted on May 07, 2010
  • Konica Minolta Master
  • 12,061 Answers
Service call 17 Toner Pack means that your toner pack cannot rotate, you must fix this. The links below are all advise on how to rectify your problem and some software tools, to help you reset your printer.
http://printer.konicaminolta.com/service/ASP/mc2300/documentation_manuals/mc2300SM.pdf
http://www.futuregraphicsllc.com/lit/tg/minolta_2300_dl.pdf
Minolta Magicolor 2300 toner chip resetter
http://www.w109.com
http://www.w109.com/2008/en/class.asp?lx=small&anid=62&nid=623&Page=2
toner chip resetter drum chip resetter
reset toner/drum chips Very easy , Significant cost savings ,Protecting the environment,
You need to get a manual like these ones, a Service manual, for your exact make and model, but perform the troubleshooting procedures, and hopefully you will be able to sort it out.
Canon ic-1320 toner rubs off copies
if toner rubs off then fuser unit is not heating paper to fuse toner to paper. You may notice paper printed on is not hot .
Jul 14, 2016 | Canon imageCLASS D1320 Laser Multifunction...
Faded printing issues with Brother MFC-9320
Try cleaning the corona wire on each toner cartridge. This may help solve your solution.
If this does not help try another thing.
Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended.
To see how to replace your toner cartridges check here
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
A white streak appears on the right hand side of the print out
If faded prints happen even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust at the laser reflecting mirrors inside the printer.
I have worked/ serviced similar Laserjet Printer with same issue.
Actually, faded prints are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 31, 2011 | Epson Aculaser C1100 Printer
Replace wt pack
The waste toner bottle is nearly full and will need to be replaced. The printer will be able to print approximately 50 more pages and then will no longer print until the waste toner bottle is replaced.
Here's an article in the Lexmark website on How to Replace the Waste Toner Bottle. Just click on this link: http://bit.ly/c4gVUM. Follow the instructions carefully. Hope this helps.
Jul 05, 2010 | Lexmark C500n Laser Printer
Price of cartridge of samsung ML-1640 mono laser printer
Rs. 2800/- original carteige
Rs. 1200/- compitable cartridge
Nov 09, 2009 | Samsung Laser Multifunction Printer Toner...
While I was moving, I put my printer without box in the car about 4 days. Then, when I reconnected the printer, it started making weired sounds and printed only spots when i tried to print someting. Now,...
I dear nex time you transport equipment of any kind ensure you pack them nicely in original packages if you threw them away look for something ideal.
So your problem could be print head is not in position :1.check print head drive belt it could be off the the drive gear.2.check also the shaft is in right position.
Jul 27, 2009 | Office Equipment & Supplies
Toner cartridge shows 70% toner but print is light
On most laser printers the toner in the cartridges is distributed by a rotating feed mechanism. This method works ok but is not the best for even distribution. Many times the toner will build up in the ends of the cartridge where the feeder can't move it around like it should. Try takeing the cartridge out of your printer and shaking the cartridge from side to side not up and down(that would only pack it tighter in the ends) After this reinsert the cartridge in your printer and try printing again.
Jun 18, 2009 | Dell 1815dn All-In-One Laser Printer
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
