Question about Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
My rangemaster 110 ignition spark will not turn off after ovens have lit
Hi, I have the same problem did you find the solution?
Posted on Jun 16, 2010
I have a rangemaster classic 90 dual fuel..we have changed the spark generator. Now it sparks on all burners but when the oven is lit the sparking continues on all burners, how do we stop this?
Hello Stephany,
this cooker has an ignition system by pressing the knob of the item that you want to ignite.
As all sparkplugs work and only the oven is the source of the problem, i think that the contact behind the knob of the oven sticks
It looks like this one and is behind the facia, between the knob and the valve.
I hope this helps, Dik
Mar 25, 2017 | Rangemaster Kitchen Ranges
Clock and ingnition not working on a rangemaster dual fuel stove
  • Hello David,
    when the clock does not work, the (left hand) oven will not work too I suppose.
    Often when the clock does not work, it is only the timer that does not work. In that case, the timer can be bypassed. The oven still works then, but without the timer and the clock will also work as a clock.
    So no timer.
    When it is an older rangemaster, and the ignition does not work, then probably are some wires leaking. I that case the power for the spark does not come to the burner sparkplug.
    But when all plugs do not spark then there are 2 possibilities I think.
    1 the ignitor is gone
    2 the ignitor does not get power
    I hope this helps, I wish you a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Mar 05, 2017 | Rangemaster Kitchen Ranges
Rangemaster 110 no ignition power to oven
Most likely is that some muck is shorting the electrodes in the oven, or underneath. Give the over a good vacuuming both inside and under
/ around the back.
Failing that you'll need to isolate from mains before testing any wiring.
Jul 30, 2014 | Rangemaster 110 (Gas) Kitchen Range
Ovens won,t function, no spark or gas but gas hobs work fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 30, 2010 | Rangemaster 110 (Gas) Kitchen Range
Oven ignites but the ignition continues to click
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 08, 2010 | Rangemaster 110 (Gas) Kitchen Range
Oven is igniting but not getting hot
got the same problem on a rangemaster 110 - just had the comet engineer look at it - changed the thermostat and the spark generator - no effect. poss the flame failure device or the timer.
Nov 15, 2009 | Rangemaster 110 (Gas) Kitchen Range
Griddle burner wont spark
Make certain the burner and burner base are very clean by carefully washing in warm soapy water, using a plastic brush to scrub any residue off the surfaces. Also clean the spark ignition nub in this same way.
Jan 23, 2009 | Rangemaster Proffessional 110 Gas Kitchen...
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
Jan 20, 2008 | Rangemaster 110 (Gas) Kitchen Range
Gas oven operation
spark should stop when burner is lit.clean the probe with a light sandpaper and see if this corrects it.
Sep 24, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
759 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
