I have lost access to my CD rom and DVD drive
I was trying to install the software for my Blackberry on my computer now I hae no access to the Atapi Cd-rom drive or Optiarc DVVD RW AD-7190a. I am unable to locate the free downloads for these device. Please help!
Thanks!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
For which device for balck berry you can download from blackberry site
Posted on Mar 27, 2008
SOURCE:
I need driver for Hitachi GD2000 2X ATAPI/E IDE DVD-ROM Drive to complete a win7 install
You're not going to get an install then. If that is NOT an OEM Install disc, you might have to try another drive to do the install with. Most ATAPI/IDE Drives are run by the BIOS.
Feb 01, 2014 | Compaq HITACHI GD2000 2X ATAPI/E IDE...
Minister Ruland and Steven Waldon are two of FIXYA's greatest spammers - love to see the blocked. Hitachi GD2000 2X ATAPI/E IDE DVD-ROM Drive driver sparky i moved hum to the endzone, see now.
once you install the drive into yuour computer it will auto setup the driver for it. now if you have xp and then you can find the driver online. winodws 7 and up should auto install most of the time the drive comes with a cd that has nero on it so you can install nero and burn dvds and cds if it does not you can down load it on the net
Feb 01, 2014 | spamfighter.com Computers & Internet
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
Hi! my computer was just reformat and need to install driver for cd rom but i don't know which software should i download from internet. please help me how to find it for my atapi dvd a dh20a4h.
easiest way to find it for any dvd cd rom drive:
open the device manager
(F1 type "device manager" there will be a link to open that up)
find your CD drive in the tree and open properies.
it will tell you who manufactured the drive and what model number the drive claims to be (might be differant than the sticker)
google the manfacture and they are required to keep archives of all the devices they make.
if your using a more modern version of windows you can tell windows to use a differant driver from the properties page of the device. usually an atapi drive will work with a generic atapi driver from microsoft.
Jun 10, 2010 | Intel Motherboard
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Jun 25, 2009 | Toshiba Satellite A75-S226 Notebook
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
Toshiba DVD ROM SD M1302 driver
If you are using Windows 98, 98SE, ME, 2000, NT or XP, and have an ATAPI/IDE CD/DVD drive, there is no driver needed (see Toshiba statement I have posted below). Under no circumstances, if DVD is properly installed and functional, will you need ANY driver!
If your DVD drive is a SCSI drive, then it may need drivers specific to the SCSI card you have installed (see the specs/manual or website for your card). You may also need the Adaptec SCSI setup, available at this address:
http://www.adaptec.com/worldwide/support/suppbyproduct.jsp?sess=no&language=English+US&cat=%2FTechnology%2FSCSI+Software&fromPage=driverindex
or use this address if you have a LOGIC based SCSI card or device:
http://www.lsilogic.com/
Now, if you meet the criteria for the first paragraph I wrote, and your PC does not load the driver automatically (after a reboot or two) then you have a PHYSICAL or HARDWARE problem. Either the DVD drive is improperly cabled, improperly installed or defective.
Those are all your options. See below, from Toshiba website
good luck
http://sdd.toshiba.com/main.aspx?Path=ServicesSupport/DeviceDrivers
ATAPI CD-ROM and DVD Drivers
Toshiba's CD-ROM and DVD-ROM drives do not require any unique device drivers for Windows '95/'98/2000/XP/NT.
After installing your drive and re-booting, your system should recognize your CD-ROM or DVD-ROM. Win '95/'98/2000/XP/NT Operating Systems support all Toshiba ATAPI CD-ROM and DVD-ROM drives natively.
DOS/Windows 3.x Device Drivers
This device driver is to be used with DOS/Windows 3.x operating systems. Do not use this driver with Windows '95, Windows '98, XP or Windows 2000 unless you are going to use your system in the REAL or MS-DOS Modes. Device drivers for Windows '95, Windows '98, Windows 2000, XP, OS/2, and NT operating systems are provided with the installation or setup software of each operating system.
DOS ATAPI Interface Driver
If you prefer using DOS click the link below to download a MS-DOS ATAPI interface driver.
atapi.exe
SCSI CD-ROM and DVD Drivers
SCSI interface drivers are written for the SCSI card you are using in your system, by the SCSI card manufacturer. They are not specific to your Toshiba drive and are not provided by Toshiba. If during installation Windows can not find the correct SCSI software driver for your SCSI card and you do not have the software driver that came with your SCSI card, contact your SCSI host adapter manufacturer.
Adaptec SCSI Drivers
LSI Logic (Symbios) SCSI Drivers
DVD Viewing Software
Toshibas DVD drives require a third party software to be installed in your system to enable you to view DVD movies. If you purchased your drive as part of a kit, the software may have been included. The links below will provide some possible solutions should you not have this type of software.
Nero6 (Toshiba recommends)
Toshiba does not recommend nor endorse any of the following manufacturers software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
DirectDVD
Cyberlink PowerDVD
WinDVD
Media Burning Software
Toshiba's recordable drives require third party software to be installed in your system to enable you to burn media. If you purchased your drive as part of a kit, the software may have been included. The link below will provide some possible solutions should you not have this type of software.
Toshiba does not recommend nor endorse any of the following manufactures software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
NTI CD & DVD Maker
Gear DVD & CD-RW
Roxio Toast (Macintosh)
Easy CD Creator
Stomp Clinkn Burn Pro
Feb 24, 2008 | Computers & Internet
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Open Questions:
Computers & Internet Logo
118 people viewed this question
Ekse
Alun Cox
