Question about Comtrend CT 300 (CT-300) Modem
How do I set Nitro Mode on a comtrend modem - Comtrend CT 300 (CT-300) Modem
Internet will not go through my comtrend CT-5072T modem
Need a bit more background on this.
Did you just go out and buy this device and hook it up to the phone line ?
Are you using ADSL line Filters ?
Did you ring your internet service provider to guide you through setting up the account settings in the modem ?
How are you connecting to the device to your P.C ?
Jan 25, 2015 | Comtrend Adsl2 Ethernet Router Model:...
No ip on comtrend ar-5381u, will not connect to internet
DO NOT INSERT A PAPER CLIP TO RESET THE MODEM! unless you know how to reprogram the router, this includes having complete knowledge of ALL the settings required by the ISP AND having your username and modem password (modem authentication passwords are not usually provided to the customer) Doing a "hard boot" will only return your modem to factory settings
Dec 21, 2012 | Comtrend CT-507 Router
Drivers for comtrend ct-5611t
Check out this link:
http://www.comtrend.com/links/13$snd.htm
Oct 15, 2012 | Comtrend Adsl Usb Modem (ct-351)
I have a comtrend ADSL2+Ethernet Router hooked to my desktop Pc and a G-Wireless Router made by Belkin.According to the tech I should be able to connect these two to use my Laptops, but any way I've tried...
You dont need a Belkin Disk to set up - this can be done manually you can get a manual from this site http://en-us-support.belkin.com/app/product/list/q/routers/ select G in the first dropdown and then your model - theres two to choose from and then then the version
you have a choice - you could change the comtrend router to just use the modem - bridged mode - they have a few different routers see here http://www.comtrend.com/links/i$residential-adsl2-modem-router$product.htm so not sure which one you have if you can bridge to just use the modem then connect tothe Belkin and all PCs should connect to the Belkin
OR you can connect two routers together Leave the comtrend router set as it is -
Set the IP address of belkin router to same subnet as the comtrend. Depending on the DHCP range of the comtrend router - set the IP outside this range - so if comtrend is set to give an ip of 192.168.0.2 to 192.168.0.100 - set the belkin to 192.168.0.254 Disable the DHCP in the belkin.
Connect the comtrend LAN to one of the Belkin LAN ports - you may need to use a crossover cable. On the belkin the WAN port will be left unconnected
Mar 20, 2010 | Belkin (F5D7231-4) Wireless Router
I have a comtrent 5361t router/modem i cannot get
Try manually assigning your computer to an IP address in the same subnet as the Comtrend.
For Example: Set the computers IP to 192.168.1.5 with a Subnet Mask of 255.255.255.0 and default Gateway of 192.168.1.1.
If that does not allow you to access the admin page at 192.168.1.1 then try resetting the router.
Good Luck!
Nov 18, 2009 | Computers & Internet
Installation of the modem Comtrend CT-361 under Windows Vista
This appears to be an old model. Their website isn't very user friendly and they list no kind of tech support available. You can contact them here.
http://www.comtrend.com/na/contact.htm
They might be able to help you out if you call them but there is nothing available on their website or anywhere else that I see on the web. The product appears to be older then Vista and might have never had a Vista driver made for the product.
Oct 01, 2009 | Comtrend Adsl Usb Modem (ct-351)
MTU settings
where do i go to change the mtu settin on a comtrend ct-5364a
Sep 11, 2009 | Computers & Internet
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
Bridge mode
Comtrend ModemLogin: root Password: 12345
May 18, 2007 | Comtrend CT-507 Router
Comtrend CT 300 (CT-300) Modem Logo
64 people viewed this question
Top Comtrend Computers & Internet Experts
Julie Endres
mathur_1
cwradio73
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
