Question about Fuji FinePix J10 Digital Camera
I have a Fuji J10 with a broken sceen
I have a new screen and I have undone all bar two scews that will not undo. These two screws are next to the tripod screw hole.
1 . Can you advise if I need to undo
2 . Can you suggest how.
  • 1 more comment
  • barnaby1 May 07, 2010
    Hiya,
    Just realised when looking that these earlier they are different. I am in the UK but I noticed that the Duratool will ship. Do I need the full set or will any of the smaller sets have the driver I need ?
    Thanks for your help, I thought I was going mad.
    Is replacement of the screen easy once I undo these screws.
    Keith
    Thank you soooo much for help. Tools ordered.
  • Fuji Master
  • 19,396 Answers
Hi.
At least one of the screws at the base must be removed, as this is surely holding the external case. If the two screws are different he other screw may be the screw used to regulate the lens (several camera models only).
If the two screws look the same, then they must both be removed.
To remove the screw(s) at the base, you will need a security screw driver. This is done to avoid non authorized persons disassemblying the camera.
The part number for the original Fuji screwdriver is ZJ00583-100. The part is provided to registered technician only.
If you want to disassemble the camera by yourself, you can use a security screwdriver set similar to the one here: DURATOOL. This sets are the only tools of this kind available to the public. Naturally, do it at your own risk.
Ensure that you have removed the screws at the sides of the Fuji before removing the ones at the bottom.
Regards.
Ginko.
Posted on May 07, 2010
  • Ginko
    Ginko May 07, 2010
    Hi.
    If you are not a technician better buying the whole set. As said the security screwdrivers are normally available only to authorized technician.
    Security screwdrivers can be purchased from UK company. Unfortunately most of them does not give details on the single tips included. Big sets include all common tips, like the one for the screws used by Fuji (three cuts type).
    After removing external case you will need to undo a couple of screws behind the back case.
    To avoid risk of discharge, the two flash condenser (capacitor) contacts should also be jumped to allow discharge. A different way to discharge the flash is by leaving the camera without batteries for a long time. As said, for safety reasons this operations must be done by a technician.
    Here the discharge procedure on a similar model:
    Here how to remove the LCD. Disconnection of flat ribbon connector nr.3 is also a delicate operation.
    Here some UK kit:
    http://www.toolsandleisure.co.uk/toolzon...">Toolzone 33pc
    http://www.transtools.co.uk/store/prod_8...">Silverline Bit Set - 100 Piece
    Regards.
  • Ginko
    Ginko May 07, 2010
    Hi.
    You are welcome.
    Thanks for the nice feedback.
    Ginko.
Change sceen
A replacement screen maybe available from this WEB site.
www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Laptop repair info
http://www.laptoprepair101.com/
Feb 11, 2012 | Computers & Internet
Replacement screen for finepix J10.
ask at a camera store they can probably order one in for you if not try kijiji
Dec 28, 2009 | Fuji FinePix J10 Digital Camera
Can the internal memory of my fuji j10 be deletede
yes,,do you have your service manual, if do .go to it, or go to you camera menu and delete it from there,,,easy as one ,two, three...
Good luck and and have fun taking beautiful pictures....
Nov 02, 2009 | Fuji FinePix J10 Digital Camera
I just buy a fuji finepix j10 2 month ago ,last weekend the lcd screen was broken ,where can i replace it?thank you
thank you for the e-mail, I had solve the problem because I decided to buy another new camera
Oct 24, 2009 | Fuji FinePix J10 Digital Camera
I need a new usb port for camera
You can try etech.com or ebay for most likely chances of finding this part. Otherwise, Fuji will do it for $50
Sep 16, 2009 | Fuji FinePix J10 Digital Camera
Finepix j10 screen dosnt turn on
I had exactly the same problem with a Fuji J10 last week. The camera would turn on, take pictures ok, but the screen was blank. Not even the icons showed or playback previous photo's.
The problem turned out to be a damaged usb port. All the pins were bent and touching each other as well as the shell of the usb port which should be earthed to the board.
Aug 28, 2009 | Fuji FinePix J10 Digital Camera
The LCD is broken. I can still use it, it makes good pictures, but it is broken. Can I change it? How much will it cost me? Thank You!
If it is still working then only the casing is broken. Have it replaced. Visit their website and locate a vendor near you.
Aug 02, 2009 | Fuji FinePix A920 Digital Camera
Lcd screen has black spot inside, outside fine, takes pictures
you should replace the lcd screen from an authorized service center. or you can buy the lcd screen alone from ebay and find someone to replace it .remember
never open the camera unless you know very well how to replace it.thanks for using fixya. please dont forget to rate my solution
Jun 01, 2009 | Fuji FinePix J10 Digital Camera
Broken screen
I have the same problem......I NEED HELP!
Jun 09, 2008 | Nokia 5300 Grey Cellular Phone
Fuji FinePix J10 Digital Camera Logo
224 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
