Question about Behringer EUROPOWER EP2500 Amplifier
What is the best level to set the gain - Behringer EUROPOWER EP2500 Amplifier
  • Behringer Master
  • 5,603 Answers
Try to set the gains at about half throughout a system. This is for best signal to noise ratio.
Be careful with these powerful amps that your speakers are rated above what these amps can deliver.
Posted on Jun 08, 2010
Setting the mic gain an rd gain on a158edx cb radio
unless you are right next to a station that has some power, set RF gain to max. Mic gain can be set at max level to 3/4 with no problems. If you have an amplified mic, then mic gain should be set at about the 12:00 position. hope this helps
Nov 29, 2016 | Radio Communications
What is the best formula of testrone booster ?
Natural food is the best way to improve your body health and also it boost you testrone....
Jan 05, 2015 | The Health & Beauty
What is the best amp setup to get that bakersfield tele sound with a fender tele.
Normally, the best way to get a very clean sound is to set the master to maximum and then bring up the preamp gain to the level you need.
Jul 28, 2014 | Peavey Windsor Studio Amp Combo
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
No problem i just bought it today from a pawn shop
turn ur amp, gain level all the way down,then turn ur deck vol.up 3/4 (100=75)(example)..now go back to ur amp. and start turning ur gain level up until ur speakers start to distort, then start turning ur gain level just until the distortion goes away,now ur amp is at max output
Feb 12, 2010 | Jensen JPA285 Car Audio Amplifier
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to have the best sounding hit from the subs?
they want you to "level match" the amps head units voltage from the rcas .this is best done with the radio at 3/4 volume , turning the amps gain dial till music distorts then backing off till it sound s clear .if theres other units in the signal chain (eq,x overs, ) see if they too have gain /volume controls . it goes down the line if thats the case . .
Nov 23, 2009 | Pioneer Car Audio & Video
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Jan 27, 2009 | Clarion DXZ545MP CD Player
I own a samsung ln46a530 and need to configure it for the best picture.....any recomendatios?
If you haven't already bought a nice set of HDMI cables, go ahead and do so (just dont fall for the "gold plated" cables as they are a gimmick). Unfortunately, while we all want that HD quality, there seems to be some problems with the ln46a530 when switching from RCA to HDMI. On the bright side, they have been resolved in this forum post.
Best audio settings:
Mode: Custom
SRS TruSurround XT: On
Auto Volume: On
TV Speaker: On
(# of clicks):
Balance: 0
100Hz: 8 clicks right
300Hz: 8 left
1kHz: 4 left
3kHz: 3 right
10kHz: 5 right
For best picture:
Most accurate settings
(This with the mode at movie)
Backlight = 6
Contrast = 85
Brightness = 49
Sharpness = 0
Color = 50
Tint = G50/R50
DETAILED SETTINGS
Black Adjust = Off
Dynamic Contrast = Off
Gamma = 0
Color Space = Custom
Red: R33 - G0 - B0
Green: R18 - G52 - B0
Blue: R11 - G0 - B51
Yellow: R49 - G53 - B0
Cyan: R22 - G46 - B56
Magenta: R37 - G0 - B43
Flesh Tone = 0
Edge Enhancement = Off
Xycc = Off
WHITE BALANCE
R-Offset = 26
G-Offset = 25
B-Offset = 22
R-Gain = 30
G-Gain = 25
B-Gain = 25
PICTURE OPTIONS
Color Tone = Warm 2
Digital N/R = Off
HDMI Black Level = Low (actually it's disabled when playing Blu-ray)<-- set this according to your source! If you use a PC, or aPS3/Xbox360 with expanded RGB levels, you might need to set this tonormal!
Film Mode = off (disabled)
Blue Mode = Off
Energy Saving = Medium
Entertainment modes = Off
Hope this helps!!
Dec 01, 2008 | Samsung Televison & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Behringer EUROPOWER EP2500 Amplifier Logo
61 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
