Question about ICP DAS I-7561 CR (I7561CR) Serial Adapter
I-7561 CR (I7561CR) Serial Adapter: The USB is detected when connected to the PC but t...
The usb is detected when connected to the pc but there does not seem to be any communication between the i-7561 and my other 485 device. When I replace with a good unit it works.
Help 68538702001
Here's what I would try first:
  • Open Device Manager and look at the properties of the device and all USB Root Hub entries. Under the Power Management tab, deselect the check-box for "Allow the computer to turn off this device to save power".
  • Don't let the computer go into Sleep mode under Power Management.
Also, I would think a serial device might draw a lot of power, getting pretty close to the 500 ma limit imposed on USB ports. The device might be more dependable if connected to a powered USB hub, which might not have this limitation.
Dec 12, 2013 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
Samsung E2210L Connecting to PC wont recognise
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make
Apr 10, 2010 | Cell Phones
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
Usb to serial converter
1. The USB to Serial has a comm port number, you can change that in Control Panel>Hardware and Software >Device Manager>Click on the adapter and make sure it's not disabled and try COMM 3 or a diffrent port you might have two conflicting each other.
I use Allen-Bradley and I also have to run it as admistrative privleges.
Hope this helps.
Jul 28, 2009 | Acer ALU 131 (91.AB861.001) Serial Adapter
How do I connect my garmin iii plus to my modern pc for downloads?
Looking for a way to connect a serial device to the USB port on your PC or Mac? Our USB High-Speed Serial Adapter provides a simple and reliable solution. This adapter is broadly recommended by serial device manufacturers due to its dependability and "Best in Class" compatibility.
http://www.tripplite.com/en/products/model.cfm?txtModelID=3914
$45.99
Mar 22, 2009 | Garmin GPS III Plus GPS Receiver
Problem with an usb-rs232 adapter
There is a good chance the weak spot is your serial to usb adapter. The signals are not compatible so the adapter has a chip and serial driver to convert the signals. If the adapter is not fast enough to convert the signals, you get an error. Here is some more info on adapters.
5 Steps for Selecting the Right USB to Serial adapter
Mar 04, 2017 | Televison & Video
Usb 2 usb 2 pc
Do not attempt to plug a USB cable between two PC's.
There is a way to do it, see this article,
http://www.hardwaresecrets.com/article/248
Oct 04, 2008 | Griffin Technology iMate - Universal ADB...
Driver incorrect
Hello, look the device VID & PID in
Control Panel --> System --> System Properties --> Unknown Device --> Details
Es. I Found on my notebook : USB\VID_067A&PID_7561\5&1737F18D&0&2
Then Modify SER2PL.SYS with your VID & PID
Es. :
[ControlFlags]
ExcludeFromSelect = USB\VID_067A&PID_7561
[Pro]
%DeviceDesc% = ComPort, USB\VID_067A&PID_7561
Reinstall the driver
Aug 05, 2008 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
Windows doesn't detect the adapter
may there is realy a defect on that card. just try use another card and see the result.
Aug 13, 2007 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
ICP DAS I-7561 CR (I7561CR) Serial Adapter Logo
243 people viewed this question
Top ICP DAS Computers & Internet Experts
David Payne
David Payne
Are you an ICP DAS Computer and Internet Expert? Answer questions, earn points and help others
