It has power but won't work!
It was working perfectly and all of a sudden a loud noise, and powered off. Now when I turn it on the mute sign flickers a couple of times and turns off. It is not the fuse because it has power, but I don't seem to get anywhere. Help! I have a Kenwood Receiver KRV5580. It was working alright but all of a sudden the display does not show up on powering up. The power is on but the 'Muting' indicator blinks for sometime and nothing seems to work. Please help ASAP!
  • Anonymous May 06, 2009
    I bought my amp around 1993. The other day, the radio was on and everything was normal. All of a sudden, for a few seconds the radio reception sounded a little fuzzy, as if an airplane had interfered with the signal. After a couple of minutes I noticed that there was no music playing. I thought that maybe there had been an electrical surge, but everything else was on. So, the power is plugged in; the CD player that is plugged into the amp comes on, but no lights come on on the amp -- no stations, nothing.
  • 4,234 Answers
There is a problem with the output stage of the amplifier section and the whole unit is in "protect" mode. This means that the output section is turned off. The output transistors are the likely defective parts here. Expect a repair cost of $15-$40 in parts plus the local labor rate.
Dan
Posted on Mar 27, 2008
My Canon LBP6000 printer has suddenly stopped working and, when switched on, gives a loud rattling noise. What is wrong?
If you have extra used cartridge, try replacing the cartridge. If there's no noise, change your cartridge with a new one.
Oct 09, 2014 | Canon Office Equipment & Supplies
The tv usually turns on but all of a sudden it won't. When it does turn on it makes a loud noise like a boat. Someone told me its the fan but I'm not 100% sure though. The noise stays on until the tv
Sounds like the motherboard on the TV has failed. Would recommend replacing the TV or taking it to a TV repair shop which may cost more than just replacing it.
Jan 30, 2013 | Televison & Video
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
2007 jeep liberty suddenly won't start after
Try starting in neutral. Gear sensor may be heating up and not registering park.
Mar 03, 2012 | 2007 Jeep Liberty Sport
It just will not turn on, I have had it for 4 years. It worked perfect all the time no problems. All of a sudden one day went to turn it on and it just wont go on. There were no signs leading up to this...
The power supply board has failed. Very common problem on this model and especially this brand. Buy another power supply module that is compatable....different modules used in the same set.
May 05, 2010 | ViewSonic N3251w 32 in. LCD HDTV
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Mar 09, 2008 | Audio Players & Recorders
Picture perfect but no sound
maybe you paid only half of your power bill
just joking .. can you hear a hum or noise of any type from the speakers ?
Jan 26, 2008 | Zenith L20V36 20.1 in. EDTV-Ready LCD...
213 people viewed this question
 Grubhead
Grubhead
