Question about Campbell Hausfeld 2" 18GA Brad Nailer
2" 18GA Brad Nailer: I was given a CH nailer as a gift about a year ago...
I was given a ch nailer as a gift about a year ago. Went to use it today for the first time. Using the brads that came with the machine and the Campbell compressor I find the nailer does not deliver any brads. Just makes the loud air release sound but nothing else. I am not sure of the model number but it is the small one. The only number on the machine is DJ0306. I tried both the brads and the staples with the same result.any help would be appreciated. mel macneill
  • 65 Answers
SOURCE: brad nailer does not retract enough for brads to enter nailer
hi check to see if there is any wear on the blade or even if it is broken if so replace with a new item from your dealer , this will also come with a new seal so with a good clean your gun should bee like new hope this helps ian
Posted on Mar 25, 2009
  • 142 Answers
SOURCE: My brad nailer shoots staples without any problem
the only suggestion i have is that you may have a feed problem, so i would clean and lube the track the nails run on
Posted on Mar 27, 2010
  • 5603 Answers
SOURCE: when I pull the trigger, the nailer just goes
The first thing that comes to mind is they are not being oiled properly. Follow the directions for the number of drops of air tool oil to put in daily. If they have been run dry, this makes quick work of the Orings and requires rebuilding the nailer with new Orings.
The second thing is if contamination has gotten into the cylinder bottom thaat can happen if a jam has ever occured.
Dis-assemble the nailer and inspect for these conditions.
Posted on Jun 11, 2010
  • 1388 Answers
SOURCE: does the campbell hausfeld model
Sb504000 works just fine with pressure range from 60 to 120 psi depending on material. Any small compressor will work great. Using the gun at max pressure will shorten the life of the gun. Best practice is to set pressure to just under 100psi for most work and increase pressure when nailing hard wood. Using at max pressure will strain the driver and the lower part of gun (screws that hold nose to body). Some hard woods will bend an 18 gauge nail. Good luck with your gun and have fun with your projects.
Posted on Aug 11, 2011
H2_Brad
  • 425 Answers
SOURCE: gun leaks
No it is not. It should not leak at all. Where is it leaking air from? The 3 obvious places are the exhaust at the top of the head, the nose where the driver comes down, and the trigger valve.
Posted on Aug 25, 2012
Nail holder will not lock
Make sure the head of the nail is in the grove.
Oct 04, 2016 | Campbell Hausfeld 2" 18GA Brad Nailer
My senco fusion 18 nailer won't set nails
is this a air nailer or something eles. if it is a nail by air adjust the air for more pressure
Jun 10, 2014 | Senco 6E0001N 18GA Fusion Brad Nailer
Air goes to gun but when trigger is pressed nothing happens, after pressing on board. gun is new
Same problem with mine. Right out of the box. Will shoot the first Brad after that nothing. Should have purchased another brand
Jan 18, 2014 | Campbell Hausfeld 2" 18GA Brad Nailer
When I pull the trigger, the nailer just goes "futz". no brad coming out. no jam. not used over 100 psi. two nailers have given me the same problem
Jun 11, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Nailer has very little power.there are no nails jammed
What about the compressor,? Is it up to 120 lbs? Does it have a reg on it? Most nail guns run at full steam, no need for the reg at the comp. If the gun isn't leaking air, It should be working. Check it out.
May 23, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Campbell Hausfeld 2" 18GA Brad Nailer Logo
74 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
