Question about Weber Genesis Silver B Grill
Genesis Silver B Grill: I can't keep the temperature constant...
What model rotisserie will fit a Weber Silver B 250000 model gas grill
You need the Genesis E/S-series rotisserie. It is part # 7519 and can be located at the page below:
Genesis E/S series Rotisserie
Sep 14, 2011 | Weber Genesis Silver B Grill
I replaced the porcelain enameler flavorizer bars on my Weber genesis gas grll less than a year ago--four out of the five bars are bent and misshapen--no longer straight. Why??? They still look brand...
You are overheating the grill - make sure the thermometer is working on the right side of the grill lid. You should not heat above 550F (preheat) and you should not cook above 500F.
Secondly, you must clean out the drip tray (not just the aluminum foil tray but the bigger tray it is attached to (it slides out the front of the grill too). The grease that piles up on this tray can catch fire and overheat the grill (including the flavorizor bars).
Last suggestion is to get stainless steel bars next time (make sure you get the size that fits your grill because the stainless steel sizes also come a bit longer). The stainless bars are high temperature stainless steel and do not corrode. They are a bit heavier and cost about 30 to 50% more but well worth it. They clean up very easily and transfer heat to the cooking surface well. Keep them clean to keep the cooking surface hotter.
Jul 16, 2011 | Weber Genesis Silver B Grill
Grill won't heat up
i would make sure the valve on the tank is open all the way counter clockwise
Apr 24, 2010 | Weber Genesis Silver A Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
Silver C 2000 Model heats to 420 degrees with all 3 burners on Low. Normal? Weber support service has given me conflicting information. With 2 burners on Low it heats to 310-320 degrees.
That's fairly common with the lid closed and a day that is not too cool. Keep in mind that a gas flame is about 800F. Try using only one burner on low or between on and high to get a lower temperature. This is a grill, not a smoker or slow cooker.
It will run cooler with a large amount of food.
Feb 08, 2010 | Weber Genesis Silver C Grill
Temperature won't go below high
the tempature gauage could be broken they only cost about ten or twelve dollars at home depot or lowes if you havent already you may want to take grill apart and make sure when you turn burners up and down that the flame highth changes
Aug 15, 2009 | Weber Genesis Silver B Grill
Cannot get temperature over 300 degrees anymore
It was the regulator bypass.
For details see:
http://weber.com/support/faq/faq.aspx?id=1
Jul 18, 2009 | Weber Genesis Silver B Grill
How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
May 21, 2009 | Weber Genesis Silver B Grill
Weber Genesis Silver B Grill Logo
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
