Question about EverFocus EDSR1600 16 CHANNEL 160GB DIGITAL VIDEO RECORDER with AUDIO&REMOTE OBSERVATION
Solve 2x + 9x =
  • dewan nafees ahmed May 11, 2010
    assume 9x + 2x = a
    take X as common outside
    so x(9+2)=a
    which can be written as
    x= a/11
    problem solved.
    you say me the value of a
    i wil tell you value of X...
    how is this..
  • eagle338
    eagle338 May 11, 2010
    I will probably need sometime to figure this one out :D
    Guru:
  • 1,894 Answers
No response in 30 days - clearing my queue
Posted on Oct 08, 2008
  • 4,889 Answers
Unable to process! Calculation is too tough!
Posted on Jun 16, 2008
  • 13,434 Answers
11x
Posted on Mar 27, 2008
  • Ekse Mar 27, 2008
    I knew it :)
SOURCE:
Solve: 7(3x+5) = 8x - (1-4x)?
Let's rewrite as
7(3x+5) = 8x -1(1-4x)
Let's distribute
21x + 35 = 8x -1 + 4x
collect like terms
21x + 35 = 12x -1
Put all the x's on one side by subtracting 12x from both sides
21x -12x + 35 = 12x -1 -12x
simplify
9x + 35 = -1
get all the constants on the right side
9x + 35 - 35 = -1 - 35
9x = -36
divide both sides by 9 to get x by itself
9x /9 = -36/9
x = -4
check in original equation
7(3(-4)+5) = 8(-4) -(1-4(-4))
7(-12+5) = -32 - (1+16)
7 (-7) = -32 - (17)
-49 = -32-17
-49 = -49
Jan 04, 2017 | Homework
How do I solve x and y in the following equations? 5x+3y=6 2x-4y=5 Thank you
You can solve it with following method.
5x+3y=6 2x-4y=5
So 5x=6-3y so 2[(6-3y)/5]-4y=5
So x=(6-3y)/5 so 12-6y-20y=25
so -26y=25-12
so -26y=13
so y= -(1/2)
2x-4y=5
so 2x=5+4y
so 2x=5+4(-1/2)
so 2x=(10-4)/2
so 2x=6/4
so x =3/2
The value of x=3/2 and value of y= -1/2
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 03, 2010 | Office Equipment & Supplies
For instance if I have a problem of 4x+1-x=2x-13+5. how do I enter it in my T E to find wha is X
This calculator does not have a Solve function or a solver. However this example of yours is very simple that you can do it by hand. If you do not mind I will show you how to solve it. Not everything needs a calculator.
You want to solve for x. OK
  1. Start by gathering similar terms 4x-x =3x; -13+5 =-8
  2. Rewrite your equation as 3x+1=2x-8
  3. Make the +1 change side while changing its sign
  4. 4x+1 -1 = 2x-8 -1 or 4x=2x-9
  5. Make +2x on the Right hand side go to the left hand side, changing its sign in the process 4x-2x=-9 or 2x=-9
  6. Divide both members by 2. This gives
  7. x=-9/2 or -4.5 if a decimal result is required.
Hope it helps.
Dec 06, 2009 | Texas Instruments TI-30XA Calculator
Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Apr 17, 2009 | Casio FX-115ES Scientific Calculator
IF I HAVE TWO equations 5x+8y=54, AND -9x+y=26 how do i solve
use the simultaneous equation solver software available on ur ti-89 and enter the equation in the form of augmented matrix and you will get ur answer.
Dec 03, 2008 | Texas Instruments TI-89 Calculator
What type of problem is this (9x-7)-4(3x 5)
just a simple multiplication solve first which is inside the brackets 9x(-7)=-63 3x5=15 (-63)-4x15 -67x15 -1005 .. i think am rite..
Oct 12, 2008 | SoftMath Algebrator - Algebra Homework...
How to use the texas instruments ti 83 plus
Srry my friend the ti 83 is no magnificent Ti-89. meaning: you have to solve it yourself. There is a method for graphing though. Set the equation equal to zero and then plug the stuff on the other side of the equation into a graph by pressing y= and then typing it in. Then hit graph. Wait for the graph and then hit 2nd calc and select zeros. Bring your cursor using hte arrow keys close to where the line hits the x axis and press enter and then do the same except to the right of that point and then press enter twice and it will display the y which should be the answer
There are quadratic formulas for calculators programmed in tibasic for the calc but other than that there is no way to solve it
Apr 27, 2008 | Texas Instruments TI-83 Plus Calculator
Maths Equations
-3x+7y=-1 and -2x+5y=0
Jan 17, 2008 | Curtis-Mathis CM25011 25" TV
Televison & Video Logo
104 people viewed this question
Top EverFocus Televison & Video Experts
Ekse
Babiepu
Babiepu
Hal Ames
Are you an EverFocus Televison and Video Expert? Answer questions, earn points and help others
