Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD-52525 52 in. Rear Projection HDTV Television: My grandson sprayed water on the screen and it got...
My grandson sprayed water on the screen and it got in behind it and put a dark stain on it. As it dries it is getting lighter but there is still a stain. Can it be cleaned?
  • 160 Answers
Only if it is the protective front screen that the issue is with. the only way to take the protective screen out is to open the tv. A service tech can do this for you however it will not be a cheap fix.
Posted on May 07, 2010
My grandson spilled some water which got into my mitsibishi tv and created a black spot in the lower left hand corner. How can i fix this?
Take it apart and clean the dried water spots off. Its hard to say if it will work but that's the first thing I would try.
Jul 30, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-62525 62 in. Rear Projection HDTV. I can see only half of the picture. It is like there is a black curtain over half the screen
The only things that will cause that issue is something called a DMD board. very costly to replace, but check with service center near you. if its not under warranty, consider replacement with a lcd tv, sorry to deliver the bad news.
Feb 21, 2011 | Mitsubishi WD-62327 62" Rear Projection...
Where is the reset button for Mitsubishi WD-62525 62 in. Rear Projection HDTV Television?
Right on the front of the set to the left of the Power Button area you'll see a small hole. Use a paper clip point and insert to push the reset. Hope this helps!
Nov 12, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My grandson has squirted milk in different areas of the screen it is dryed up what is the best thing to do to try and clean these spots off some 3to 4 inces wide looks kind of black
this is what i do in the workshop warm water in a bowl with a little washing up liquid & a clean soft cloth ring it out then go over spots u my need to do the whole screen as one area is now very clean . do this very softly .
Apr 11, 2010 | Hitachi 51F500 51" Rear Projection...
I have a Mitsubishi 57" projection tv, Model# WD-Y57. There appears to be some type of liquid betweent the 2 screens. Is there a way to clean this, or do I need to buy a new screen?
Remove the 2 screens and clean then wirth only micro fiber cloth and mild cleaning solution dry and reassemble. be sure to put back screens in same ostions.
Feb 18, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Water
You can remove the screen by removing the screws around the perimter of the screen, from the rear on the top and sides, and from the front on the bottom.
Here is a PDF with the instructions.
Hope that helps!  Good luck!
Jan 24, 2009 | Samsung HLN5065W 50" Rear Projection...
TV's screen goes blank but sound continues
You will need a can of freeze spray to find the cold solder joint on the main board.Depending on how easy you can access it.Use a mirror to see your screen while you spray the board to localize the area of the problem on the board.Then remove the board and with a magnifying glass or googles find and re-solder the bad spot.Good luck and let me know. -edcarson
Feb 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
231 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
