Question about Saeco Magic Comfort Plus Espresso Machine
Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
How to descale saeco magic comfort
  • 1,089 Answers
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
Posted on May 07, 2010
How to ventilate Saeco Magic Comfort + coffe maker
Hi
If its a Magic Comfort + there is a water button on the panel (with the drop) that you push for water. You twist the dial for steam only.
If its a Magic Delux you twist the dial for water.
Nov 21, 2010 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort plus: Despite descaling the machine twice, the Descaling notice remains lit on my screen. Brews great coffee but what gives?
Hi
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Jan 09, 2010 | Saeco Magic Comfort Plus Espresso Machine
"Steam" function not working properly on Saeco Magic Comfort Plus
Most likely the nozzle is plugging up. Use a piece of wire and run it through the nozzle a few times.
please mark this answer as a fixya
Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
Steamed milk is not coming out
Clean the steam wand, it unscrews and needs to be cleaned, also, descale the machine once the blocked tube is cleaned. When milk dries it is like glue and clogs the steam wand. so clean it daily after use.
Also, I think you meant to say, steam for milk frothing is not coming out. If you meant steamed milk is not coming out, it's not supposed to do that. Some Saeco's can add an attachment called a milk island but not the magic comfort plus.
Mar 04, 2009 | Saeco Magic Comfort Plus Espresso Machine
Got an old saeco magic comfort 7/8 years old -
You are correct to descale the machine. I am not sure how "decalcification" is different, but if the message is still coming up, you may need to have some repair work done. There are some sensors inside that can be cleaned manually if a descaling solution doesn't do the trick. You can do some work if you are mechanically inclined.
Jan 20, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus not dispensing coffee
Try setting the grind to the coarsest setting, if you still have the same problem, then descale machine.
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Rinsing...Warming UP... message on Saeco Magic Comfort plus
HI, I am sure you have solved your problem, however:
If you Descale the machine and let it Rinse to complettion of the
cycle; it resets the machine and it will start Rinising after warmup.
Otherwise press the Menu button and go to Energy Saving
then press the Esc buttton. This allows the machine to start
without Rinsing. Also you may turn Rinsing to Off in the Menu.
Nov 04, 2008 | Saeco Magic Comfort Plus Espresso Machine
How old are your machine?
What number is the grinder on?
How often do descale the machine?
/Mirran
Aug 26, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
2,461 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
