Question about Refrigerators
Repairing refrigerator door seal
I am trying to get some advice and information on how to instal
refrigerator door seals and can't seem to get some manuals or
on line advice on the subject.
Can you help me out?
Thank you
Faamausili Taiva Ah Young
    Problem Solver:
  • 10 Answers
Thank you!
Posted on Mar 29, 2008
  • 4,889 Answers
Surething.. Click here
Posted on Mar 27, 2008
How do I repalace a door seal on the Kenmore refrigerator?
Remove the door makes the job easier. Using a table lay the door with door seal in the upright position. Pinch and pull the door seal over to one side to expose the door seal screws. Remove screws and gasket/ seal and install the new door seal in the reverse order.
Feb 07, 2014 | Refrigerators
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
Brand new upright Freezer forming Ice above top shelf and now drops of moisture inside door model WFM1800 door seems to be shut tight
Is the unit level to the ground or platform it sits on? The reason I ask is that many cases after closing the door a vacuum occurs, after this vacuum settles the door can allow gap in which will cause this issue. So with out opening the door or 10 mins after, check the door seal to assure a good seal. Some door can be modified to seal by heat (blow dryer or steam). BUT, inspect unit before assuming this is the issue! I can further assist you in how to apply heat to reform gasket on door or even reshaping door to seal better if needed.
Get back to me on model you have and the results of your findings about this seal issue.
Basically, you have an air leak and this is the cause of a seal issue. Results in a condensing warm air mixing with cold air and causes ice cycle to form. Usually around the top because heat rises and cold air drops. With this information you can adjust the door to meet the cabinet and seal you years to come.
Good luck and feel free to send me information if needed.
Oct 23, 2013 | Westinghouse Refrigerators
Hi, I have a whirlpool refrigerator model WRB101.
If a new seal is needed then you can call any appliance sales store and they an order one in for you with the correct information, or you can call the manufacturer of the fridge and they have a parts line you can order your parts directly from them. Good luck
Sep 08, 2012 | Whirlpool Refrigerators
The door does not closed. the sealer is bad can i be fix?
it sure can in fact there are company that specificly replace fridge door seals. but if you can get the seal from your nearest appliance spares retailer its simple to fix if you pull the rubber right back at the base you will see lots of hidden screws if you take them all out the inside panel will fall of with the seal on it pull the seal off and repalce with new one and re attach panal with all the screws
merry christmas
please take the time to rank this advice
Dec 22, 2010 | KitchenAid Architect Series II 29.7 Cu....
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My refrigerator door won't stay closed!
Don’t mess with this or you could invoke the manufactures warrantee. Contact Customer Services
http://www.samsung.com/uk/support/onlineservice/onlineService.do
Nov 07, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Need advice on how to replace brandt CFA361XU freezer door seal.i have the new seal but cant remove the old one.cant see any retaing screws.and seal doesnt seem to pop out. thanks
i shouldn't do it
seal is foamed in and i'v not had any success on replacing foamed in seals. applies to all makes
sorry to be negative
Jul 02, 2008 | Refrigerators
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
