Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
My homelite chainsaw model# ut10520 has aoil leak from the flexible line at the base of the oil tank.
    President:
  • 2,220 Answers
I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 07, 2010
Homelite chainsaw ut10560A leaks bar oil, how do I replace the oil tank and check the pump and oil lines?
Would say the tank is not problem, believe this model may have a check valve In cap, would replace or repair cap and check lines for holes. Maybe this drawing will help.
Nov 18, 2017 | Homelite Garden
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
Engine racing at idle
some sealing is not correctly installed or is broken- to much air in gas ----
Apr 05, 2014 | Homelite Garden
Is there a replacement part other than plastic for clutch
you could either use an organic rubber type simelare to platsiic and do it urself - size etc
Apr 17, 2012 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
I have a Homelite UT 10520. It is a refurbished chainsaw. It has ru about 30min. It is running hot. My mixtture is 50:1 and my gas is 90 oct. I think it is running lean. It will not get to the max...
lI thinkthe oil to gas is too rich with Gasoline. My book says 40 to 1. Not enough oil will cause it to run hot and burn or stick. Also some of the later models take the synthetic oil andif you use the outboard or other oil it will run hot and ruin the saw.
Jul 07, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Gas/oil ratio
The ratio is 50:1.
If you appreciated my help, I'd appreciate your vote. Thanks,
Handie Andie
Apr 07, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Need fuel mixture specs
50:1 is the fuel to oil ratio using a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to mix the fuel and oil in it's own container, and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Feb 03, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Homelite XL2 Auto - Proper Oil Line Hookup
Go to m-and-d.com then parts diagram, then illustrated parts online, then parts look up then select oem type select homelite then type in the model no. The parts diagram should show correct hook up.
Apr 06, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
596 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
