Question about Sylvania 6513DD 13 in. TV/DVD Combo
Universal Remote Code Needed
My remote for the Sylvania 6513DD no longer works and I am trying to program a universal remote to work with it. None of the remotes listed for any Sylvania codes work, and I have gone through the search process with the universal remote for hours with no luck. Does anyone know a universal remote code that works with this model? Thanks!
  • boozy13j Feb 23, 2009
    I have a 32 inch sylvania tv. I have tried different codes with no success. any idea?
The code is 11963.
Posted on Apr 06, 2008
SOURCE:
What code will work with a universal remote for the LD 195 SL8? I have tried four various universal remotes and none have worked.
I can t give you any specific codes as they will be different for each remote. However, if you have tried all the codes for Sylvania, then also try codes for the following brands. All of the brands in this list are made by Funai who also manufacture the Sylvania LD195SL8:
Funai
Emerson
Durabrand
Symphonic
Superscan
Try codes for the above brands and also try the code search features on your universal remotes. You will find details of these in the user manuals. If neither the codes for Sylvania or the above brands or the code search feature work, then it's unlikely that the remotes will work with the TV. Universal remotes often fail to work with Sylvania machines for no apparent reason.
Regards
BElectric
Dec 04, 2010 | Sylvania LC-195SL8 19 in. LCD TV
I need the three digit code for the ge universal remote control for sylvania 6513DD please.
Hi, You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thank You
Nov 06, 2010 | Sylvania 6513DD 13 in. TV/DVD Combo
Comcast universal remote control does not have setup code
Try 1864. It worked on my Media-Com remote when none of the other codes worked
Sep 12, 2009 | Sylvania LD320SSX LCD TV
Universal remote code for a sylvania tv/dvd Model
I went to Radio Shack an purchased a 15 dollar Phillips universal remote and it worked after entering one code for sylvania combo tv's. I did the Happy dance and now I can watch my tv again.
ONE FOR ALL® URC6131n Universal Remote Control
JiggyChic
Apr 06, 2009 | Sylvania Televison & Video
We're looking for the code number to program our universal remote
Find out what company makes the remote. Do a search for that company along with the search words: remote control tv codes. Their web site should be happy to help you with a list of all the tv codes.
Nov 17, 2008 | Sylvania LC320SS8 32 in. LCD Television
Sylvania LC155SC8 remote TV code for Verizon Fios
There is no code!!! -- Solution...You have to buy a universal remote with learning capabilities. I’ve ordered one that will not only learn off other remotes but can handle 10 components also. I got it from 10x it’s called the iconRemote control…if you call the company they will give you a discount (but you have to call them and ask) AWESOME!
Feb 21, 2008 | Sylvania LC320SS8 32 in. LCD Television
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Need code for universal remote Sylvania LC320SL8
We bought a Sylvania LC420ss8 HDTV.
Our current universal remotes would not work, I followed the advice on this site and got a Sony
RM- VL600 Sony Untergrated Remote Commander, use page 16 in the manual to teach the new remote off of the remote that came with the TV. It really works. I am happy with the tv and remote.
Dec 07, 2007 | Sylvania LC320SL8 Television
Sylvania 6513DD 13 in. TV/DVD Combo Logo
1,102 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
