Question about Weber Genesis Silver C Grill
Genesis Silver C Grill: 1997 weber genesis silver 1000. On Crossover ig...
1997 weber genesis silver 1000.On Crossover ignition 3 burner style only front burner has flame;other two just gas smell. Only one front burner light and ss burner is only 3 years old had original 10 years and replace with original weber parts from Weber Corp.
  • 63 Answers
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Posted on Mar 14, 2009
  • 512 Answers
SOURCE: Weber Silver Genesis C regulator purging gas after reset process
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
Posted on Jun 17, 2009
SOURCE: How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
Posted on Jun 13, 2010
  • 4736 Answers
SOURCE: Bought a weber genesis 320 Problem with the Weber
Normally, at least on an American grill hose/regulator assembly are a universal fit. And both ends of the hose have female couplings. I would think it would be the same on German Models too. For the connection to the grill, the hose coupling size is 3/8" ID.
Posted on May 08, 2011
  • 4736 Answers
SOURCE: replacing the crossover ignition system
What you're referring to is called a Collection Box. It traps gas so it will ignite. You can purchase a new one directly from Weber or from Appliance Factory Parts http://www.appliancefactoryparts.com/
Hope this helps you get the part you need. Happy Grilling!!
Posted on May 19, 2011
My weber genesis E 330 thermometer never goes higher than 400 degrees F Why?
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jun 04, 2014 | Weber Genesis Silver B Grill
Weber genesis
i would say you have a fulty regulator to save your self sone money
rather than buy name brand you can find them on other sites
i hope this helps you
May 24, 2012 | Weber Genesis Silver B Grill
I think I need a new crossover ignition system for a Genesis 320 natural gas grill, where can I get one? I cannot find the correct one on your website.
Nancy, we don't have any parts on the FixYa website. But, if you're referring to to the crossover burner, that lights the last burner, you can find it at the following link under "tubing". http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/weber-tubing.html
Hope this helps you and Happy Grilling. Thanks for choosing FixYa.
Aug 02, 2011 | Weber Genesis Silver B Grill
Replacing the crossover ignition system in my weber genesis silver b grill. it has a propane tank. the small metal cover over the spark ignitor has rusted out.
May 19, 2011 | Weber Genesis Silver B Grill
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Dec 30, 2010 | Weber Genesis Silver A Grill
Grill won't heat up
i would make sure the valve on the tank is open all the way counter clockwise
Apr 24, 2010 | Weber Genesis Silver A Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
May 21, 2009 | Weber Genesis Silver B Grill
Weber Genesis Silver C Grill Logo
117 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
