Question about Sylvania 6615LFP 15 in. EDTV-Ready LCD Television
Keeps turning off
Every 5 min it turns off my tv keeps turning off. upper half of the screen is a bit dim. the tv is a 15" lcd sylvania. it could be a bsted backlight or a problem with the ccfl inverter/driver. tell me where to order parts.thanks
    Scholar:
  • 66 Answers
Do to the extreme difficulty in finding parts for LCD tv's and monitors, I need the number and maker information on the front of the inverter. It is a inverter problem and I am currently working on a magnavox with no suppliers anywhere. Hear is what they look like.
http://www.pchub.com/uph/model/0--7839-1/QPWBGL945IDG-parts.html
The inverter board is Sampo QPWBGL945IDG LCD and if you click on the photo to enlarge you can see the Sampo number.
Being a 15" like I am working on a universal one may work for you.
Backlight
-Inverter_W0QQitemZ180226402058QQihZ008QQcategoryZ61398QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem">http://cgi.ebay.com/Universal-Two-output-LCD-Panel-Backlight-Inverter_W0QQitemZ180226402058QQihZ008QQcategoryZ61398QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem
First lets see if we can find your inverter. Please give me the info off the inverter and we can go from there. Be careful taking it apart, get organized and keep everyone away. Set your screws in different holders so you know where they went, take photos- this helps great when taking stuff apart if you cant remember where everything went. You will need to purchase some metal tape found in the auto dep. at walmart or Lowe's. When you take the screen apart you will see what I mean. You have to cut the tape , the inverter will be on the back under a metal shield which the inverter will have 3 plugs [ maybe more ] but I am thinking it has 2 tubes, one on the top and one on the bottom. Any way, look at this site and it will give you an Idea on how to get at the inverter.
http://www.inventgeek.com/Projects/BacklightFix/Page1.aspx
Even though this is for lcd monitors the principal is the same so lets get it fixed - but I will need the number off the inverter, this should get you started to take it out, it is a good Idea to replace the cfl's also, they have about a 33,000 hour [ about 3 year ] life. That is a little more risky but we will get into that later. Please send me the info and we will help all we can on getting you up and running!
Take Care - The best of luck
Kevin
Posted on Mar 27, 2008
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Oct 29, 2012 | Sony KDL-46NX810 46 in. 3D LCD TV
Turn on picture and sound are great. for about 60 seconds. then the picture disappear but sound is great. turn power off wait a little bit ( try differ times. from 15 seconds to 10 minutes) Turn back...
The tv have a long board call a LCD inverter board.This long LCD inverter board is dead.That why,the tv have picture only flashes like a min. than,died and have sound left only.The LCD long inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Oct 16, 2010 | RCA L32HD32D 32 in. LCD HDTV
TV won't stay on
I would suspect either some capacitors failing in the power supply, a bad solder connection, or a component drawing too much current. Replacing the power supply may fix it.
Apr 02, 2010 | Sylvania LD370SS8 37 in. LCD Television
My Sylvania flat screen sound keeps going off
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/ The most probable cause is with its audio output IC itself; overheats.
May 11, 2017 | Sylvania Televison & Video
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Half of the screen turns black after 10 mins 46" Sceptre LCD TV
YOU PROBABLY HAVE DEFECTIVE LCD PANEL THERE IS A SLIGHT CHANCE IT IS THE MAIN BOARD OR THE LVDS CABLE
Apr 10, 2009 | Sceptre X42GV-Naga 42 in. LCD Television
Image lost after 5 min turning on the tv, sound was ok.
I would suspect overheating of an electric component in the power supply of the lamp (backlight) of your lcd tv. bring it in for repairs.
Nov 29, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Black screen after 1-2 minutes.
Hi, I just fixed one I bought on eBay with the same problem. My problem was caused by the screen backlight inverter. Fortunately I had one from another TV I bought last year on eBay. The repair only took about 15 minutes. Your best bet is to contact Funai Corp. and really complain even if it is out of warranty. They make Emerson, Funai, Symphonic and Sylvania and all the parts inside are the same (from the same years). If that don't work look on eBay for one with a broken screen or some other damage, call your local dealer and see if they have the inverter from a broken TV or ask around. We have a freecycle group in Michigan that recycles things rather than throw them in landfills you may have one in your state too !
Good Luck,
Jul 15, 2007 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Sylvania 6615LFP 15 in. EDTV-Ready LCD Television Logo
668 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
