Question about Home
I have a roca dama toilet seat which needs tightening but see no way to open the sealed unit
  • 159 Answers
Don't know about a roco dama, but most have color coded plugs where the screws go in, you will need to look alittle harder.
Posted on May 08, 2010
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
How to fit replacements roca soft close hinges on a toilet
These hinges are completely replaceable and I sell them. Here is a step-by step manual how to do it yourself:
http://roca-parts.eu/roca-softclose-repair/
Sep 24, 2011 | Home
Toilet seat slips
You will need to tighten the bolts holding the seat to the bowl. This video well help although the seat may not be the same as yours.
http://vodpod.com/watch/793915-tighten-toilet-seat-bolts
Mar 08, 2011 | Jacuzzi Home
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
I have an integral toilet built into a unit. the toilet seat is broken, but i can't find an opening to release & tighten the hinges that hold the seat
The manufacture could tell you how to take the seat off, with out a model number i cant tell you how to take it off.
Mar 23, 2010 | Home
Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
Feb 13, 2010 | Neptune FB1621 Murano Toilet
Loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
Feb 11, 2010 | Toto Drake ADA Compliant Toilet with...
Leaks when cleaning the bowl. Bowl moves a bit. Plumber was afraid to tighten bolts too much for fear of breaking bowl. How tight?
Leaks at the floor or the tank where it meets the base behind the seat?
Generally tight enough to sinch it so as not to leak.
If the whole unit moves on the floor the wax ring may need to be replaced. If the tank leaks be sure the bolts are tightened evenly with new gaskets sealing them inside the tank. Tighten the nuts evenly until it stops moving freely and the leak should stop.
Dec 17, 2009 | Toto Aquia II Dual Flush Toilet
Home Logo
883 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
