Question about Toshiba 62HM195 62" HDTV
I have a toshiba dlp hm195
I have vertical lines on my screen and cannot get rid of them
  • frank gonzalez Sep 05, 2008
    i have a toshiba 62hm195 and the picture has vertical lines from the middle of the screen to the bottom
  • mirandajones Nov 30, 2008
    I have a Toshiba 62MX195 and vertical red lines suddenly appeared. Please notify me if you have a solution.
    Cordially,
    Craig Hudson
White spots on dlp
Posted on Aug 24, 2008
SOURCE:
After replacing the dlp chip in my mitsubishi tv there are vertical lines on the screen. any ideas?
i had the same lines on my 65' mitsubishi tv after replacing the DLP chip. after going back over everything i realized that the casinf that holds the chip in was not in the lock position. i took the chip out and replaced it then turned the little locking mechanism to the locked position. now my screen is perfect. hope this helps.
Nov 21, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I have vertical lines on my 65inch Toshiba DLP. How can I fix it?
Vertical lines would suggest a problem with the optical light engine which might not be cost effective to replace---check to see if problem on ALL inputs.
Aug 26, 2012 | Toshiba 65HM167 65" Projection Television
Vertical white lines appear on the screen. Samsung provides the following information but doesn't say what circuitry they are referring to. Samsung says: DLP TV: I Have Vertical White Lines...
That answer I agree makes no sense.
Most of these sets have NO vertical hold and if did it will not cause the lines.
A brief educated guess:
Set has a main board that communicates and controls the screen--tests for that are not simple (checking waveforms with a scope and signal generator).
The model indicated here is a DLP that uses a lamp (let me know if model listed is not the one you have).
In DLP sets aside from main/digital board you also have a optical light engine---it processes all signal in and out to the screen.
Optical engines do fail and cause some simple and some complicated picture issues.
Some will even cause the set to "lock up" with a picture or strange looking screen---clue to this is you have to shut the set off by pulling the power cord.
The set may be old enough they do not really want to help you or even talk about it.
May 22, 2012 | Samsung HL-S6187W 61 in. HDTV
I own Toshiba DLP Projection 62 HM195. I hav e replaced D95LMP Lamp, Direct Tv installed new LNB at Dish, and new Receiver. I am losing picture quality. Is my problem O[ptics? Color Wheel? Is this a part I...
It could be the cable from the receiver to the TV. Check to see if the cable is an RG-6 and NOT RG-59 cable. Are you able to use RCA cables? They get much cleaner pictures and sound. If this still is a problem, you can get a small TV and connect it to see if the problem is still there! If it is, then your cable coming for the Dish could be bad. I believer the Cable Company will warrant that! I hope this helps...
Jan 06, 2011 | Toshiba Televison & Video
I have several verticle lines on my screen, how can I get rid of themm?
Vertical lines on your LCD usually tells you that your screen is failing. You can do a quick verfication by plugging in an external monitor - and if the external monitor looks normal, then that ought to confirm it.
Once you have vertical lines on your screen, there's no way to get rid of them - it's pretty terminal unless you're into repairing microelectronics. For replacement screens, eBay would probably be your best bet.
Mar 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have two vertical lines down my screen Is there anyway to get rid of them?
It sounds like your graphics card is jolted. I don't know a true "fix it" solution, but what I would do is call Toshiba.
Sorry I couldn't be more helpful. Good Luck!
Jan 01, 2010 | Toshiba Satellite P35-S611 Notebook
I have 3 colored vertical thin lines running vertical on my desk top screen, how do I get rid of them? thank you
Does it do this if you attach an external screen and view windows through the external screen. If not, then you have a fault with the TFT panel on the laptop. This would require a replacement TFT panel.
Oct 15, 2009 | Toshiba Satellite A60 Notebook
I have a TOSHIBA lap top, recently there are
Does the laptop have integrated or dedicated graphics?
This could be a problem with the graphics drivers. Go to the Toshiba website, and get the latest drivers for you PC, this should solve the problem. If this doesn't solve it, than it looks like the screen / graphics controller / GPU is failing.
Jun 23, 2009 | Compaq Presario M2000 Notebook
Vertical black lines
Sounds like the light engine. Very easy to replace.
Feb 09, 2008 | Toshiba 62HM95 62" HDTV
Toshiba 62HM195 62" HDTV Logo
475 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
