Question about White Sewing 972 Mechanical Sewing Machine
972 Mechanical Sewing Machine: I have a problem with Singer 972 sewing machine. T...
I have a problem with Singer 972 sewing machine. The bobbin stitch is too lose and how can I fix it?
    Genius:
  • 1,116 Answers
Always thread a sewing machine with the presser foot up and this will eliminate what looks like a loopy bobbin thread.
If you thread with the presser foot down, the tension control is not open to accept the thread as it is designed to do.
Then when you sew, the tension cannot control the top thread and the bobbin thread pulls the loose top thread to the bottom of the fabric.
Normal setting for the tension is usually mid-range ( 4 or 5).
Posted on May 07, 2010
Where do I take my sewing machine to get fixed?
sadly we have no idea where you live , so we can not check for you. try the singer website at singerco com
May 13, 2016 | Singer Sewing Co 7258.CL Stylist Sewing...
I have a singer 500/550 .I'm trying too sew a straight stitch ,but I'm having trouble with the tension. What's the best setting? And i can't sew with needle in the middle position. Why
500/550? wow, that an old one. have you check your timing? or the bevel gears?
what type of problems are you having with the sewing. is the thread knotting up on the back side of the fabric? is the thread just breaking? or is it just missing stitches? does the needle hit the bobbin case?
I have a 600 series and I found that if i put the tension around 2 or 3 it sews the best.
too tight the tread breaks, too lose the thread knots up on the back.
I had to change out the bevel gears and have the machine re-time to stop the miss-stitching.
also may want to check your bobbin tension.
May 29, 2015 | Singer Sewing Machines
Sews about 5 stitches then stops and beeps. stitches look fine, just will not keep sewing
count the beeps and refer to the owners manaul as for troublshooting tips
Dec 03, 2013 | Singer 8780 Sewing Machine
Singer touchtronic 2010
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
adjust the top tension one number or letter higher when the stitches
on the bottom are loopy, until the stitches become normal
also change the needle--flat side to the back side of the machine
check with singer website for a manual--some times they have free
pdf downloads
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 2010)
Click search
having a machine serviced once a year is a good idea & makes the machine last longer
and the sewing machine shop will tell you if they can get parts for the machine & if the machine is worth the money to fix it.
I myself have 2 sewing machines, when one is being serviced then I have the other one to use, so I'm not with out a sewing machine when I need one.
good luck
Debbi
May 17, 2012 | Singer Sewing Machines
I have a singer sewing machine Model #4622A. I cannot get the bobbin case to stay in the machine. It will sew a little, then the bobbin thread gets knotted up and the fabric gets caught in the foot feed....
Hello. Are you putting the presser foot down before sewing? Check also the stitch length, set it to at least 3, and make sure it's not set to a darning stitch or hand embroidery stitch that lowers the feed dog.
Aug 16, 2011 | Singer 7462 Mechanical Sewing Machine
Thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Mar 12, 2010 | Singer 5050 Mechanical Sewing Machine
Loose stitching
if your machine, lose the stich, adjust the tension, and fix your bobbin.
Oct 11, 2009 | Singer 8280 Mechanical Sewing Machine
Thread bunches up from bobbin feed.
Remove the needle plate and clean the feed dogs there could be fluff gathering.
Check your needle is not damaged.
May 30, 2009 | Singer 1120 Mechanical Sewing Machine
Hand held singer sew quick
Remove the plastic pin holding the bobbin (thread source) - careful to not lose the spring.
You may need a pair of pliers to get it loose the first time.
Press down on the edge of the bobbin so the pliers can grip the pin - lay a piece of material over the pin so the plies do not gouge the plastic - twist and pull.
Aug 05, 2008 | Singer 7462 Mechanical Sewing Machine
White Sewing 972 Mechanical Sewing Machine Logo
565 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
