Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
(F5D8231-4) Wireless Router (F5D82314): need password to setup...
Need password to setup
  • 2,260 Answers
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Posted on May 07, 2010
I want to make a password
You can create password from 'wireless' option in router setup page. Here you can type your own password.Read more
Aug 22, 2012 | Belkin (F5D8231-4) Wireless Router...
Forgot my security password.
you'll need to perform a reset and reconfigure it:
Setup steps:
  1. Locate the reset hole on the router. The button will be on the back or side of the router.
    See images below:
  1. Leave the router powered on.
  2. Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  3. Remove the paperclip.
  4. Wait approximately one minute for the router to restart.
The settings for the router have now been reset back to their default
Jan 06, 2011 | Belkin (F5D8231-4) Wireless Router...
My only concern is does my belkin g wireless router will work in the philippines. i am using pldt mydsl connection
Yes Compatible With my DSL pldt Just setup the user name and password Tel number @pldt
and your password that is your referent number.
if your connection is Dynamic just power cycle the modem and the router
Oct 10, 2010 | Belkin (F5D8231-4) Wireless Router...
Forgot security code
Yes you can reset the router and it will come back to the factory default settings.
now you can connect the computer to the router. open the setup page of the router and setup the router manually without the CD. if you want to secure the network. you can do that also.
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
Click Here
for step by step instructions
Jul 08, 2010 | Belkin (F5D8231-4) Wireless Router...
How do i install my router i have one care on my computer and it wont let me install my router. How do I bypass this?
You may manually configure your Belkin router. Make sure that the computer is connected to the ethernet port (gray) of the router. Then the modem is connected to the WAN port (yellow) of the router.
On your computer's browser, type: 192.168.2.1
It will prompt you for your password. By default, just leave the password field blank.
Once in the setup page of the router, go to Internet/WAN tab. Under connection type, you need to select the type of your connection depending on your ISP. If you are not sure, contact your ISP and ask them if they use PPPoE (you will also need the username and password for your connection) or DHCP, Static, etc.
Then next and then apply changes. Once the router has the correct settings from your ISP, you should be able to get online.
For the wireless settings, just go to Wireless in the setup page and you may change your settings like enabling wireless security.
I hope this helps!
May 15, 2010 | Belkin (F5D8231-4) Wireless Router...
How can I retrive my password or wep key off my Belkin wirelless router I bought a new laptop and can't acess my router
Use a wired computer to access the setup page of the router.
On the browser's address bar, type 192.168.2.1.
By default, leave the password field blank.
Once on the setup page of the router, go to Wireless then Security. You can get the WEP key from this screen.
Or if you would like to turn off wireless security, just change the security mode.
However, I strongly suggest to enable wireless security so that other people will not be able to use your wireless network.
I hope this helps!
May 14, 2010 | Belkin (F5D8231-4) Wireless Router...
Hi I have one wireless router N1, I need change my password , but I forgeto ,,,,,You can help me
Use the reset button of the router, to change the password into factory settings.
Here's the manual for your Belkin router.
http://cache-www.belkin.com/support/dl/p75170-d_f5d8231-4_man.pdf
The reset button can be found on Page 13 of the User Guide Manual, this is the instruction on how to reset your router.
There is no password by default.
Note: Using the reset button will delete all the settings of your router that entered by a user, be sure to put back all the settings according to your internet provider setup connection.
Jan 31, 2010 | Belkin (F5D8231-4) Wireless Router...
How do you set a password for the wireless router after installation
I have a belkin router as well. in your address bar in you internet browqser (internet explorer, netscape, etc.) type in http://192.168.2.1 This will bring up your router configuration page. Go to the section that lets you set a password. (It is probably under wireless security) and set a password or "network key". If it asks what kind of security you want (eg. WPA, WEP, etc.) I would simply choose WPA. It is not the strongest security, but it is the easiest to setup and unless you live in a densely populated area ( e.g. new york apartment) it is all you should ever need. If you have any questions feel free to ask me at lilchicken_dean2@yahoo.com Hope I could help!
Nov 06, 2009 | Belkin (F5D8231-4) Wireless Router...
Showing red light on router have to keep taking lead out and plugging it back in also someone has got in on my skype account and used it, is the router secure and what can i do to make it safer
You need to setup wireless security. Not sure pprecisely which model you have but log into the router and select WPA security. You will need to do the same on all the other devices which wirelessly connect to it (right click on the wireless icon>properties. Afterr you have done that change your skype password
Oct 24, 2009 | Belkin (F5D8231-4) Wireless Router...
I need to set up without installation disc. I have a belkin n1 router and can not find the install disc. Im back online but without security.Cant figure out how to get my password put back on the router.
you do not need the disk.
you can log in to belkin router by typing 192.168.2.1 and press Enter, in your internet explorer (in the address bar ),
click on "wireless" on the left, click submit without entering anything (for the password), and you can click on security. and u can setup the key from there. but best to call them and theywill help you. call them at this number 8777365771
Jun 18, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
444 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
