Question about Apple iPhone Smartphone
IPhone Smartphone: outlook saves one date i-phone one day out...
Outlook saves one date i-phone one day out
  • 33 Answers
It seems that you might have set different time zone on Pc and Iphone so it is giving you this problem pls set proper timezone in both of them your problem will be solved
Posted on May 07, 2010
Outlook calendar appointments sync to IPhone but appointments made in Iphone do not sync to Outlook
so what u trying and wanting to do with it here being coneected meens its looking at whatever in i pohone not what u did before cuse if u set it to work online it would edit the date so ya set it offline so it dont think its contecting online program so trricky what and do u have latest firmware in i phone and updates for office outlook ?
Jan 19, 2008 | Apple iPhone Smartphone
IPhone Smartphone: I have an Iphone 3G and Itunes 9.1 and MS Oulook 2...
make sure dates and timezones are correct and synched on both computer and iphone.
May 17, 2010 | Apple iPhone Smartphone
Iphone outlook sync problem
before connecting the iPhone to the pc, verify if the regional settings, as well as date and time settings are all exactly the same on both devices. this issue may be caused by a difference in settings for daylight saving time or time zones. also check if the device's location matches the location set on the computer.
Apr 20, 2010 | Apple iPhone Smartphone
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
I have read all the msg boards and am still not able to sync my iphone 3gs to outlook. does it have anthing to do with running Vista? I used to work then notice that it changed
Vista shouldn't have anything to do with it, unless your using a 3rd party software to connect it.
First thing, Update iphone to latest version.
Update outlook 2007 using windows update.
The resent update to the iphone firmware and itunes fixed the problemof things not moving from iphone back to outlook.
BEFORE the fix for the iphone , to get an event to show up back in outlook , you would need to make it a recurring event on the iphone starting and ending on the one day ...
to test if thts the problem you have , make a new calendar event in your phone and make it recurring, starting and ending on the same day.
sync, then check outlook.
Before this update to get things working I needed to do the following...
1) backup your outlook .PST file. 2) rename and move the existing pst file, and create a new one.. 3)import the contacts 4) import calender events, (not recurring ones) 5)sync.
Taken from: stu @ http://forums.whirlpool.net.au/forum-replies-archive.cfm/1044679.html
Oct 19, 2009 | Apple iPhone Smartphone
I am switching from a palm centro to a new Iphone 3g. They said I could transfer data thru itune application. HOW?
You'll need outlook or outlook express, but you can export your Palm phone data to your Outlook Contacts, and then, using iTunes, import your data from Outlook.
Jun 27, 2009 | Apple iPhone Smartphone
When I add an appointment to my iPhone and then synch it with Outlook, the appointment shows up 8 hours earlier in Outlook. The other way around (add an appointment to Outlook) the appointment is 8 hours...
one of the problems is that a web server can be overseas and an end user can be far far away.
One suggestion after checking current answered questions is to turn the time zone support off.
turn the Time Zone Support off.
Settings-Time&Date-Time Zone Support off
Jun 10, 2009 | Apple iPhone Smartphone
Iphone sync with Outlook 2003
i want my emails from my Outlook 03 to wireless sync with my iphone
Apr 24, 2008 | Apple iPhone Smartphone
How to sync contacts from iphone to outlook 2003?
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
Jan 30, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
