Question about Sony SLV-N88 VHS VCR
SLV-N88 VHS VCR: what is the universal remote code for this sony vc...
What is the universal remote code for this sony vcr?
  • 4 Answers
SOURCE: Sony VCR date only goes up 2006
I have 2 SLV-696HF units that won't work after 2007. I have had people tell me that I'll have to "find" a previous calendar that will work, since there are only 14 different calendars in our Gregorian system, 7 for non-leap years & 7 for leap years. The problem we have with this, is that the internal VCR calendar won't roll BACK far enough. I wonder if SONY has a way of flashing these units to fix this problem?
Posted on Mar 03, 2007
SOURCE: Sony SLV-SE820 VHS VCR
o Front display,wrong functions on front buttons.
CAUSE
Corrupted data is stored in the NVM memory (IC605) or part of the data is erased.
The model option data flags are erased or set incorrectly.
SOLUTION
1. CAPACITOR AND RESISTOR REPLACEMENT NOTE
For continuous reliability, regardless of the symptom, ALWAYS check and replace if necessary C701 in the correct mounting position and ALWAYS modify R668/R669 from 10k to 4.7k.
1.1. Open the set and replace C701 "470µF 10V" (1-126-925-11)
1.2. Make sure to mount C701 in the correct way, the positive (+) side points to the edge of the MCB. NOTE THAT THE WHITE PRINTING FOR C701 ON THE MCB IS INCORRECT (REVERSE)!
1.3. Replace R668 and R669 "10k" (1-216-675-11) with "4.7k" (1-216-667-11).
2. OPTION DATA SETTINGS
2.1. Connect the unit to the AV input of a television with a SCART connection cable in order to enable the on-screen display.
2.2. Enter the unit into test mode: press the record button on the front panel, then press the menu button on the remote commander for 5 seconds until the option setting display appears on the connected television. The option display has 8 columns and 9 rows with decimal numbers.
2.3. Enter the correct option settings according to the model and model destination. Refer to the option setting table in this document or page 5-6E of the Service Manual.
2.4. The option number is selected with the FF, REW, STOP and PAUSE buttons on the remote commander.
2.5. Pressing the OK (PLAY) button on the remote commander activates the selected option number. An activated option number appears in reverse colour.
2.6. After all required option numbers are activated press the MENU button on the remote commander to save the changes. A message "Please wait" appears for a few seconds after which the setting is completed.
2.7. Turn the power OFF and back ON.
3. HEAD SWITCHING PULSE ADJUSTMENT
3.1. Remove the front panel.
3.2. Insert a VHS alignment tape (like KRV-4821PS).
3.3. Press the TEST button located behind the front panel at the left-hand side of the tape/display area.
3.4. Press the SP/LP button on the remote commander. The adjustments are operated automatically.
4. FUNCTIONAL CHECK
4.1. Re-assemble the unit and perform functional checks.
4.2. Check for correct language setting.
4.3. Confirm basic functions like Playback, FF, REW, etc.
4.4. Check for a noise-free picture quality in playback mode.
4.5. Switch the unit on and off for a couple of times.
4.6. Perform a timer record to confirm the function and picture quality.
4.7. Check the SmartLink function (if available with the connected television) by transferring the TV preset settings to the VHS recorder.
MODELS OPTION DATA SETTINGS
SLV-SE720D/SX720D
2, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 19, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720E/SX720E
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720G
3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 27, 33, 34, 35, 40, 41, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720I
3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 25, 26, 33, 34, 35, 40, 43, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720B
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 20, 21, 26, 33, 34, 35, 36, 40, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SX727D
2, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 19, 32, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE727E
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 32, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720N/SX720N
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 20, 36, 42, 45, 47, 51, 54, 60, 61, 63, 66, 69, 72
SLV-SE820D
2, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 15, 19, 23, 29, 32, 34, 35, 40, 42, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820E
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 23, 29, 32, 34, 35, 40, 42, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820G
3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 23, 27, 29, 32, 33, 34, 35, 40, 41, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820B
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 20, 21, 23, 26, 29, 32, 33, 34, 35, 36, 40, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820N
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 20, 23, 29, 32, 36, 42, 45, 47, 48, 49, 50, 54, 60, 61, 63, 64, 66, 69, 72
Posted on May 12, 2008
  • 4234 Answers
SOURCE: Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Posted on Aug 31, 2009
  • 403 Answers
SOURCE: Lost codes for v.old universal remote
All universal remotes work about the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
hansola
  • 279 Answers
SOURCE: i need the original code for my sony vcr model #
Your universal remote control should have its own list of codes for products that you want to program. Do you not have this list anymore? You should be able to locate it online. I can help you with that. What is the make and model of the remote?
Posted on Nov 13, 2009
My Sony VCR Model SLV-662HF will not accept cassettes. I am using a universal remote control. The VCR's display shows APC 71501 and 81508. Do these APC codes refer to the VCR or the All In One universal...
The codes are to program the universal remote control to communicate with the Sony VCR. Try programming the universal remote using one of these: 60000 60032 60033 60035
The acceptance of the cassettes may not be related to the use of a universal remote control. If the URC doesn't have the "equivalent" functionality of the VCR's original remote control, you may not be able to use the URC to perform the functions of the original remote control.
Dec 13, 2013 | Sony Slv-662hf 14" Vcr Plus Rmt-v266...
Need new sony vcr remote
Try searching Curry's Partmaster website, if you are in the UK.
Mar 30, 2013 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Jul 22, 2010 | Sony SLV-D100 DVD Player/VCR
How do you change the recording speed?? with out the remote.
Soory this cannot be done without remote control although tapes already recorded in sp or lp should auto select on play
regards windyhouse
Mar 29, 2010 | Sony SLV-N88 VHS VCR
Sony vcr slv-n88 infrared not working..3 different remotes work with other components but not the vcr. any sugggestions?
Bought a new VCR. Probably cheaper than going to a shop, or paying for any plans or advice, to get a repair and new remote.
Nov 21, 2009 | Sony SLV-N88 VHS VCR
Vcr clock setting
Probably you can't. That's a big pet peeve of mine with A/V equipment these days- so much of the control is by remote only and if it dies your machine is almost useless
Mar 05, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
No remote
Have you tried a universal remote control?
Nov 23, 2008 | Sony SLV-N500 VHS VCR
Remote control code
That doesn't sound quite like the usual procedure for programming a universal feature on a remote. Should have to put the remote in TV mode, then press something to get it into programming mode, then put in the code for your particular TV.
Oct 17, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-N88 VHS VCR Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
