Question about Frost Freezer WCWO F15WA FREE - POCKET HANDLE - L
Side of frost free freezer is very hot
I need to know if it is normal for the sides of a frost free freezer to be so hot that you can not keep your hand on it? this is an upright freezer with the white textured finish on the inside and outside so it is not that old it is a fridgedaire
  • Anonymous Apr 06, 2008
    I'm having the same problem, leave a message on here if you find out what's wrong and I'll do the same if I have to call a repairman.
    Sandy
    Genius:
  • 1,073 Answers
The condenser coils of the freezer anre inside the case of the freezer, they are suposed to be hot they are removing the latent heat from inside the freezer to make it cold, no heat transfer no cooling, you will notice the high heat temps a lot of the time after adding food to the freezer or when you just have started it after being turned off for some reason it is fine
Posted on Apr 21, 2008
Sides of upright freezer are very warm to the touch
Good Afternoon Chuck, thank you for your inquiry! From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the freezer. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Aug 21, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Kenmore side by side freezer is so hot on both sides I can hardly touch it.What can i do?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jul 24, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Layed down freezer to transport in car for long journey left 4 hrs before start up working fine freezing but side edge behind door seal feels quite hot since
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
Oct 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The outside of the freezer sides are extremely hot to the touch? Why? Freezing fine on the inside.
the coil normally on b ack of fridges is on sides of freezers under skin it is normal to be warm. The hotter the weather the hotter the skin.
Sep 02, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
After turning the freezer off to defrost it noted the top and sides got pretty hot.Is this normal?
yes it is as most units have a heater around the doors and inside the unit to aid in defrost and to help keep the unit frost free
Aug 09, 2010 | GE Freezers
My freezer is very hot on the sides is that normal ? the inside temp keep on flutering is that normal ?
check door gasket, proper clearance from sides.the more it runs the hoter the sides get.the cooler the room temp the less it will run ect.. does it ever shut off by the control? set control on one and listen for it to shut off wait a couple min and turn it up does it come on if it doesn't it may be in defrost so wait a wile and do it again if every time it's off it won't come on (in defrost) the cold control may be bad what temp is it in there. is it frost free and is there frost buildting up where there shouldn't be it has a defrost problem
Dec 25, 2009 | Frigidaire Freezers
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
733 people viewed this question
Top Frost Freezers Experts
ray gallant
Ken Wieczorek
Ken Wieczorek
Bill Boyd
Are you a Frost Freezer Expert? Answer questions, earn points and help others
