Question about Nikon Speedlight SB-600 TTL Flash
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
When I set my SB600 (mounted on D70) to ttl or ttl bl mode I get a dark pictures. It is ok when I set it on Manual mode. I do not know if it is the problem with my D70 or SB600.
    Problem Solver:
  • 9 Answers
The sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
Posted on May 11, 2010
Sb600 keeps flashing
The the signal to the camera to shoot flash off the camera
change your settings
Jul 11, 2013 | Nikon Speedlight SB-600 TTL Flash
Flash does not show TTL Balance. Stuck on 14mm
This is not user fixable, send it back to nikon and expect to pay about $ 120 to get it fixed
Apr 05, 2010 | Nikon Speedlight SB-600 TTL Flash
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
Intermentant --3.0 exopsure. information panel on
there is botton inthe camera BLK from there you can set it or +\ _ botton
Oct 16, 2009 | Nikon Speedlight SB-600 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Sb600 display fine, but no longer flashes
    Your flash has a bad flash tube . make sure the batteries are in corectly and youhave a ready red light .
    Nov 08, 2008 | Nikon Speedlight SB-600 TTL Flash
    Sb600 wireless mode not working...
    Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
    Mar 13, 2008 | Nikon Speedlight SB-600 TTL Flash
    Sb 600 under exposure.
    You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
    Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-600 TTL Flash Logo
    345 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
