Question about Amana DLG330RAW Gas Dryer
DLG330RAW Gas Dryer: no power when I push the knob to start drying...
No power when I push the knob to start drying
  • Amana Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 25, 2010
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
Amana gas dryer model dlg330raw will not start. Doesn't do anything or make any noise no matter what setting it is on.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 15, 2010 | Amana DLG330RAW Gas Dryer
I have a dlg330raw dryer and i have been doing laundry but when i went to start it, it hums but won' start. can you help me with this?
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101 ..
Oct 29, 2010 | Amana DLG330RAW Gas Dryer
When i turn on the dryer all i get is a humming noise, when i push in the button to start nothing happens
Usually this is a sign that either the motor is in a bind or bad. Sorry to say but the latter is usually the case.
Jan 26, 2010 | Amana DLG330RAW Gas Dryer
Dryer will not start when knob is pushed It makes a purr sound but will not start the dry cycle
Dryer Repair - The
Dryer Repair - The
heatman101
Oct 18, 2009 | Maytag MDG3706A Gas Dryer
I have an Amana gas(LP) dryer DLG330RAW that doesn't heat. When I turn on the dryer the ignitor glows red, and ignites a great flame for about 10 seconds, then I hear a click and the flame shuts down. A...
Replace the two small round black solenoids located on the gas valvle. I just did it last week. They come in a set and only cost me $26.50. Easiest fix I've done. I was all set to go out and buy a new dryer.
Sep 24, 2009 | Amana DLG330RAW Gas Dryer
The gas burner will not light.
hi bob , with the dryer on switch the unit from air dry to 1 of the heating positions ,did you hear a click?If so your problem is with your burner,if not you will have a thermostat/thermal fuse problem.possible burner issues include bad ignitor,ignition sensor .
Jun 17, 2009 | Whirlpool LGR5636L Gas Dryer
Amana LG4309w gas dryer
may be bad coils on gas valve
Jun 30, 2008 | Amana DLG330RAW Gas Dryer
Amana DLG330RAW gas dryer.
try cleaning or replacing the flame sensor ( optical unit mounted on the side of the burner tube. voltage flows though that optical eye that proves flame.
Mar 29, 2008 | Amana DLG330RAW Gas Dryer
Amana DLG330RAW Gas Dryer Logo
97 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
