Question about Zanussi ZBF360X Electric Single Oven
ZBF360X Electric Single Oven: fan oven working but no heat...
Fan oven working but no heat
  • 269 Answers
If the main oven fan is working but no heat it is most probably the ring element which is around the fan blade inside the oven.Check it is the element before you go and replace because there could also be an issue with the thermostat.Hope this helps.
Good Luck,
Posted on May 07, 2010
Think my oven element has gone how do you change it.
more info please, is it your grill of fan oven etc ?
Oct 07, 2013 | Zanussi ZBF360X Electric Single Oven
The grill on my oven will not heat up but everything else is working !
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 19, 2011 | Zanussi ZBF360X Electric Single Oven
Zanucci Electrical fault. Oven cuts out and fO8
Is the model number correct. ZBF360X.
Anyway the error code fo8 normally relates to a faulty Tangential Fan.(Cooling Fan),which can be found on teh top of the cooker behind the control panel and it is there to cool said panel.
Hope this helps.
May 24, 2010 | Zanussi ZBF360X Electric Single Oven
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Aug 24, 2009 | Candy F248P Electric Single Oven
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Oven fan zannusi zbf360x
Remove rear panel in back of oven, there you will see the fan,remove fan blade,usually left hand thread, and remove screws that hold fan, if they are not accessable from inside the oven then you will have to remove oven from housing, and remove rear outer panel to access fan screws and connections.
Remove fan and replace in reverse order.,don't forget the nut that holds the fan is a left hand thread.
Plz rate this solution.
Thanks.
Dec 14, 2008 | Zanussi ZBF360X Electric Single Oven
Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
thanks.
Nov 08, 2008 | Bosch HBL 745 Stainless Steel Electric...
Replace fan
It is a left hand thread, hold the fan as you unscrew it.
Apr 11, 2008 | Zanussi ZBF360X Electric Single Oven
Zanussi ZBF360X Electric Single Oven Logo
328 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
