Question about Casio Exilim EX-Z750 Digital Camera
Camera says memory card locked when turned on ,i want to delete card to use again contents already saved on disk
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Jan 16, 2013
  • kakima Jan 16, 2013
5 Suggested Answers
SOURCE: Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Posted on Jul 11, 2008
robmcd27
  • 423 Answers
SOURCE: can't delete pictures?
I would reset your camera to the factory settings to fix your settings being locked.
You can find that information on page 130 of your manual.
You can find your manual here
http://exilim.casio.com/current_owners/manuals
If you can't delete pictures on your camera or your card, you need to make sure Protect is not set to on. You can find that on page 90 of your manual.
Thanks for coming to FixYa, and don't forget to rate my solution.
Rob
Posted on Mar 08, 2009
xscrewdriver
  • 246 Answers
SOURCE: save from internal memory to memory card?
On play mode, press MENU, on PLAY tab-->COPY-->BUILD-IN->CARD, press SET,then wait until the "Busy...Please wait.. disappears.
Posted on Jun 30, 2009
  • 3287 Answers
SOURCE: My camera is locking my memory card. I slide the
I have had a similar problem with flimsy lock tabs. I solved it by placing a small amount of scotch tape over the tab - starting near the connection pads, over the tab to the back edge of the card. There's usually not a whole lot of extra room in the slot, so insert carefully and remove portions of tape as needed.
Worst case scenario - if you never use the locking tab (I never do) you could place a small dab of super glue to hold it in place. Let it "set up" before reinserting - you don't want the tab to move an be held on the lock position.
Posted on Sep 18, 2009
Testimonial: "Good ideas, I'll try both. I wasn't sure if it might have been a problem with the camera causing it to push the lock up, but I'll try this first"
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
My mytouch camera keeps saying sd card is full.delete some content when i didn't take photos.
Please ensure that memory option is save to SD card. if then also same happens then try with any other memory card Or SD card. if then same Update phone Software from authenticated Maintenance Shop.
Jan 25, 2013 | HTC Cell Phones
My memory card is write protected. when i turn on camera the screen is saying it is write protected, i can't take pictures or delete pictures
Hi. Thanks for your question.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Please don't hesitate to ask more questions if this is needed. Thank You for using FixYa.
Jan 10, 2011 | Nikon COOLPIX L18 Digital Camera
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
I have the samsung s630 and i have taken some pictures on it before i got a memory card. i want to save them to my memory card, but when i insert the memory card those photos wont show up. how do i get...
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Oct 20, 2010 | Samsung S630 Digital Camera
Good day, i have a nokia n81, i already reformat my phone but still the same its always been reboot when im using it, sometimes it just turn into black, specially when im saving a file to my memory card,...
As you mention the mobile reboots when you save fiels to memory card,it seems memory card contains virus.
When you formatt the phone please format your memory card also.If you have virus in your memory card again it will affects the phone again even though you formatted the phone.
Before formatting the memory card please take the backup of the content in memory card because all content will be deleted when you format it.
Please view video how to formatt the memory card.
http://www.youtube.com/watch?v=rdMHyOOPKkQ
After formatting both phone and memory still the problem presists then this may because of the software problem.please go to NOKIA CARE and reinstall the software.
Thank you
Aug 09, 2010 | Nokia N81
Memory card won't write
just check the lock on the card, it should be up holding the card straight
Apr 16, 2010 | Nikon Coolpix S210 Digital Camera
Error Message on screen of Nokia 3230 "Not enough memory to perform operation. Delete some data first! How to solve this? Already deleted so many messages in the inbox and other non related programs...
I have had this issue with a E71, i had to update the firmware this is done through the PC Suite,should solve memory issue and download new version of PC suite to sort sync issues
Dec 03, 2009 | Nokia 7610
Problem with 2GB Kodak memory card
hi if you place the memory card into slot of your pc or laptop and follow the instructions on screen or take to your nearest chemist they will be able to put your pics on to a disk for you when you have saved ther pics to either your pc or disk you can then delete the pics
Jan 09, 2009 | Kodak Easyshare M753 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
21 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
