Question about Innovage Touch-panel Phone 1502084
Volume How to I raise the Volume? I figured out how to flip thru the Setup screens by pressing the "Set Save" buttom, but can't figure out how to make it louder, especially when on Speaker Phone. Thanks in advance for your hints. no volume control on speaker operations, no explaination for VIP button
  • Anonymous Jun 06, 2008
    This volume thing is killing me. I have been trying for about 4 days to make the volume louder but with no results. Help me please.
  • 32 Answers
Hi pkeyes40, my phone is a differenet model number, but on my phone you raise the volume by hitting the hands free button, then press the delete button several times to adjust the volume ( 1-4), then press the hands free button to confirm. then hit delete to exit. hope it works the same for your phone. good luck. and if you would like me email you with the manual i have for my phone, an innovage lcd phone/caller id 1507102, it might give you some pointers. my email address is all8upinwv@yahoo.com
email me and i reply with the manual. hope i helped ya out. good luck.
tammy
Posted on Aug 12, 2008
I have a Motorola aur12000 Cordless Phone and it does not ring loud.
Hi debora maisonave!
To modify the volume level on your phone please follow this steps:
To raise the volume:
  • During a call: press the key up to raise the volume of the call.
  • When the phone is ringing: Press the key up to raise the volume of the ringtone.
To lower the volume:
  • During a call: Press the key down to lower the volume of the call.
  • When the phone is ringing: press the key down to lower the volume of the ringtone.
Hope these steps help!
Regards
Gaby
Motorola Customer Care.
Feb 11, 2015 | Motorola Mobility Dect60 Cordless W...
Have a new v3c phone that will only vibrate..no ring tones and cannot get it to ring
A couple of things could b set wrong. First, make sure you're volume is turned up. Flip phone open and push the top button on left to raise the volume. Second, open phone, go to menu, cursor to settings, sounds, call ringtone, single tone. Now cursor down thru the selections to pick a ringtone. Make sure the "no ring" selection is not selected. (The current selection will have a check mark on the right side.) Select the tone you want and push the center button to save it. You can then select all your other ring tones, such as message alerts the same way.
Sep 15, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Cant figure out how to set the time
1> Press and hold the select button. The setup display appears. 2> Press the select button repeatedly until "CLOCK-ADJ" appears. 3> Press (DSPL). The hour indication flashes. 4> Rotate the volume control dial to set the hour and minute. To move the digital indication, pres (DSPL). 5> Press the select button. The setup is complete and the clock starts. To display the clock, press (DSPL). Press (DSPL) again to return to previous display. The clock uses a 12-hour digital indication.
Jun 15, 2009 | Sony CDX-GT300 CD Player
How do I set the time?
Press menu, press global setup, press set day and time. Use volume up/down key and right soft key to go from day of week, hour, minute and am/pm.
Feb 15, 2009 | Uniden TRU8885 Digital Answering Machine
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
I have a bell express vu remote that i am trying to get to work with one of your tv's. the remote is a 3.2IR the model number of the tv is 20pt634v37or 2opt634v37 can u please help me figure out wut the...
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Finish :)
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Jan 06, 2009 | Directed 434MHZ Remote Control
Help! Cannot remove old ink cartridge!
  1. Open the front cover and then open the top cover. (Figure 1)
    Figure 1: Open front and top cover
  2. Raise the lever on the top right side of the drum cartridge. (Figure 2)
    Figure 2: Raise drum cartridge lever
  3. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
    Figure 3: Remove drum cartridge
******Very Important***************
To reset the NVRAM, perform the following steps:
Press the Menu button.
Press the (down arrow) button on the printer until Configure appears, and then press the (right arrow) button on the printer or (Set) button.
Press on the printer until Maintenance appears, and then press on the printer or .
Press the until Init NVRAM appears, and then press or .
Press Initializing and Restart Printer will appear.
Power off the printer and power back on.
Oct 24, 2007 | Dell 3100cn Laser Printer
Checking aol mail
To send and receive emails via your LG Prada phone you will first need to set up an email account Send and Receive emails on your LG Prada phone by setting up an email account. To set up a new account: From the Start-up screen select the Main Menu icon Select Message (Figure 1) Scroll down and select Settings (Figure 2) Select Email (Figure 3) Select Accounts (Figure 4) Select Menu icon Select New Account (Figure 5) You will now be required to enter some information relevant to your network provider (details of which you can find here) and existing email account: Account Name ? For example ? Hotmail, Gmail etc (Figure 6) Email Address ? e.g. bob.jones@hotmail.com Your Name ? e.g. Bob Jones Incoming Mail Server ? Click here to find out this information (Figure 7) User Name ? e.g. bobjones Password ? This is will be the same as your Gmail/Hotmail password Outgoing Mail Server ? Click here to find out this information (Figure 8) You can also set up some Advanced Settings on your email account, to do this press the Menu icon and select Advanced Settings (Figure 9). You can now edit the following settings if you need to do so, however, they will already be set to default settings: Protocol Type (Figure 10) Maximum Receive Size Save To Server Insert Signature (Figure 11) Reply Email Address (Figure 12) Incoming Port Number Outgoing Port Number (Figure 13) Outgoing Mail Authen (Figure 14) Outgoing Server ID Outgoing Server Password Once you have completed the above, press Save the in the Email Account section activate your new email account (Figure 15). You are now ready to send and receive emails. You can also change your Network Profile and set up a Signature via the main Email menu simply select Network Profile then the new profile and activate. To set up a Signature choose Signature, then New and write your Signature and press OK
Aug 18, 2007 | LG Prada KE850 Cellular Phone
Volume
Hit hands free button then the vol. button the once agian to change it from high to low.
Jun 13, 2007 | Innovage LCD Touch Panel Phone
Innovage Touch-panel Phone 1502084 Logo
101 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
Kolbrun...
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
