Question about Edimax 4 Port Wireless AP Broadband Router (br-6104wb)
Why i can't connect to internet using edimax?
  • 33 Answers
Probably it is not configured properly to provide you the IP that is the DHCP service not started in your router so you are not being able to connect internet
Posted on May 07, 2010
My psp cannot connect to Edimax internet security not supported
It is the security protocol that is not supported.
So you cannot use it with a PSP.
Jan 25, 2014 | Edimax Computers & Internet
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
My edimax br 6428ns keep on losing its internet connection...i have an internat connection around 30 min but it will stop and i need to run the setup again in order for it to work..
Check the connection type is not "Connect on Demand".
Check the Idle Time Out setting is not used.
This specifies the amount of time the router waits before shutting down an idle connection. This option is only available when "Connect on Demand" is selected. See the manual
See
http://www.edimax.co.uk/edimax/download/download/data/edimax/uk/download/for_home/home_legacy_products/home_legacy_wireless_routers/br-6428ns
Feb 07, 2013 | Edimax Network Br-6428ns Wireless N 300m...
Edimax br6204wg wan led doesn't light up and there is no internet connection
Hi yaminmagdi,
I believe that you are trying to get connected wireless using your Edimax Router, we may need to check some settings in your Edimax regarding the wan light not lit up and could be a possible reason why there is no internet connection.
1. First we will need to find an Ethernet cable for us to be able to connect your Laptop directly to your Edimax Router for us to be able to check and change any settings needed to enable your Edimax wireless connection. also make sure that the Ethernet cable is connected to the Ethernet ports behind the Router not the WAN port then the other end goes directly to your Router.
2. Once connected directly to your router from the Laptop open IE or any Browsers on your Laptop, in the Address bar type in 192.168.2.1 then press Enter this will prompt for a user name and password, User Name will be ' admin ' and the password should be 1234 unless you changed it.
3. Inside the Edimax setting page click on the Tab that says Wireless, check and see if the wireless is enabled if not then enable it or turn it on, after enabling / turning the Route ON save the settings by clicking on Apply or Save then it will prompt that the Router is restarting it will be 30 seconds to apply once the 30 seconds is up that should be done check your Edimax if the WAN light is already lit up, then you can try an connect Wireless from your Laptop.
I hope this helps.
Have a nice day.
Apr 03, 2011 | Computers & Internet
Problem with internet when using LAN
You have to set-up proxy setting for the same thing
If both your system is having Win xp then please activate internet connection sharing which is there at the network properties
or you can install 3rd party proxy also
just chek with ping uitlity weather it can ping with each other
Mar 14, 2009 | Edimax ES 3108P (ES-3108P) Networking...
Edimax Router disconnects the internet when laptop is on battery
That has nothing to do with your router.
Its your laptop that shuts off your wireless card every time its running on battery power.
Dec 27, 2008 | Edimax BR-6104K Router (br6104k)
My edimax prob.
Hi...
Use the setup wizard under Internet Explorer - (go to: Tools, Internet Options, Connections, Setup) Choose the right connection after the setup... close the IE browser and reload it... If it doesn't work... you have to set the IP and DNS to Auto.... keep me posted if your still have problems.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
How to use edimax br6104k with an smartbro isp
It's not a problem connecting to internet if your isp is smartbro, esp. if you are using a D-Link router..just plug in ur smartbro rj45 to the WAN port and connect ur pc to one of the 4 LAN port of the router that's all you can connect to internet..first time of course u have to input the username and password from smartbro in order to connect again..
May 20, 2008 | Edimax BR-6104K Router (br6104k)
Page Cannot be Displayed-IE, Edimax Router BR-6104K
Smartbro account is used directly to the computers LAN port, not on the router, One computer should be made as the server, where the smartbro connection is placed... to share the internet connection... you should have another LAN card to share Internet throught the router... "See New Network Connection" you'll see examples of proper connection.
Good luck... Fixya...
Feb 02, 2008 | Edimax BR-6104K Router (br6104k)
Cant connect on d internet
my case if i direct the cable on single PC its work we have connection but when i use edimax i cant connect...unable to connect.
Dec 09, 2007 | Edimax BR-6104K Router (br6104k)
Edimax 4 Port Wireless AP Broadband Router (br-6104wb) Logo
208 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
