Question about HTC Touch Cellular Phone
How to get files from computer to my pocket pc?
How?
  • 33 Answers
Just connect it with pc and check weather active sync/windows moblie device center detact it. then you can open your device using explorer and just copy pest the files
Posted on May 07, 2010
I Need i driver for Siemens SX56 Pocket PC
This application helps you to synchronize your pocket pc to your computer
download this link : SYNC MY PHONE TO PC
And here is the procedure
1. Install the given application
2. run the program
3. connect your phone to the computer using usb cable
4. some driver will install and wait until the phone recognize by computer.
Now your phone is synchronize on your computer,you can transfer file from it vice-versa.
Thank you for visiting FixYa.
Jul 19, 2011 | Siemens SX56 Pocket PC
How to download a games???
Hello
can you tell me which device you want to download games to? if its the imate you have selected, you can download games from http://www.freewarepocketpc.net/
you download these to your computer, connect the pocket pc to the computer and run the setup file that came in the download, it will install the game or the program into the pocket pc.
you will need to have active sync or windows mobile device center installed on the computer.
let me know how you get along with it.
Thanks,
Ekse
Feb 05, 2011 | i-mate Pocket PC
On IPAQ hx2700, how do I do a hard reset? I want
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
How to install themes
Here is your Pocket PC's default theme
wm6_default.jpg 1. Connect your Pocket PC to your Desktop using your cradle and Microsoft Active Sync, Once it is Connected double click on the green circle on your taskbar to open the Active Sync Window (If the Circle is grey, then it means that your Pocket PC is not properly connected).
2. Now you need to click on the explore Icon.
3. Here you can see the files and folders on your Pocket PC. Navigate to the “My Documents” folder. (This is where we suggest that you put your themes) . You can also use the“Windows” folder or Main directory of a storage card (not in a sub directory).
4.Now you need to drag the TSK theme files that you have chosen from your desktop computer to your pocket pc 5.Now you need to activate the theme file on your Pocket PC:
Tap Start, Settings, Today, Select your chosen theme, and tap OK.
Your new theme will now be activated.
You can download the themes from: http://www.htcfreeware.com/HTC/categories/HTC-Themes.aspx
Jul 14, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Beaming files
ok i have done some research make sure your pocket pc is a wireless system then on your computer u need a router turn it on and on your pocket pc go to find wireless network and bam u can have file from your pc to your pocket pc if u need anymore help email me at mid.nightclub@hotmail.com
Dec 31, 2007 | IBM ThinkPad T43 Notebook
Hookup to computer
connect the usb cable to the pocket pc. then, with pc on, plug the opposite end to the pc usb port. then, open My Computer" icon on desktop and then find the drive letter associated with the pocket pc. for example, if your pc has only one hard drive and one cd-rom drive, then your pocket pc letter will be e:. double-click e drive and verify your pocket pc. then mouse-drag any files from outlook folder into the e: drive. they will be copied, by default. the originals will still be on the pc.
Jun 01, 2007 | HP iPAQ H4150 Pocket PC
Activesync
Do you have it set up where the computer file always overrights the pocket pc files? If you do it would result in losing all information input on the PDA. Typically you would set it so that the last version overights the prior version. That way updates on the computer overight the PDA's old info and vice versa. The only time there is an issue is when both are updated before syncing, then you are prompted which to use. That's the first think I'd check.
Sep 12, 2005 | HP iPAQ h6325 Pocket PC
Copy file
There are many ways to copy a file to the Toshiba Pocket PC. Here are two easy ways.. via the Explorer when the Software ActiveSync is installed on your Personal Computer, a new entry can found on the left side of the Explorer Windows.A simple click on the "Mobile Device" will allow you access to the file system of the Pocket PC. via the ActiveSync Program when you open the ActiveSync Software you can find the "Explore" Button in the Toolbar. A clicking to this Button will open a new Window with the file system of the Pocket PC. Simple mark your file on your PC, "Copy" the file and "Paste" it to the file system of your PocketPC
Sep 08, 2005 | Toshiba e740 Pocket PC
Copy file
Please see the picture below:
"Pocket PC 2002 Update 2.0"
Microsoft Pocket PC 2002 Update 2 official statement This document provides useful information for end users and IT professionals to successfully update Windows® Powered Pocket PC 2002 with the latest improvements to the Microsoft® Pocket PC 2002 software included in the update. EUU2 Improvements This update provides improvements to the following problems. Calling IpReleaseAddress() causes a multi-homed Pocket PC 2002 device to stop responding. Server Sync cannot synchronize if a specific meeting is in Inbox or Calendar. ”Trouble Connecting” error appears even when a user wants to end a connection FTP User/Password authentication default overrides user “anon.” Pocket Internet Explorer sometimes does not send Submit button Name/value information. Pocket Internet Explorer is slow to load a pages with JScript®. IMAP4 service stops responding when attempting to download e-mail with certain attachments. Media Player Full Screen playback breaks on second played clip. Advanced VPN Settings will not save in Pocket PC 2002. System .WAV sound files have extra noise at the end. Setup and Installation The PPCEUU2_.CAB file includes the EUU2 improvements described above as well as all previous updates. Once installed, the device will permanently store the changes in flashable ROM, saving the device RAM for applications and program memory. Be sure to back up all of the data on the Pocket PC 2002 before beginning the installation process. Ensure that the device has a minimum of 9 MB of free system RAM*. (Refer to your owner’s manual on how to free up additional memory.) The required memory is used only for the installation and will be available again once the setup has completed. Be sure to keep the device connected to your power adapter during the updating process. * System RAM is RAM available to the device apart from additional RAM storage cards. -------------------------------------------------------------------------------- Two methods of updating your PocketPC e310: Method 1. Updating your Pocket PC while connected to the Internet or intranet Ensure that the device is connected to the Internet or intranet through either a modem or LAN card. On the device, open Microsoft® Pocket Internet Explorer and enter the URL to the Update page. (Consult your system administrator if you are not sure of the URL.) Navigate to the appropriate page to locate the PPCEUU2_.CAB file. Download the file. Answer “Yes” in the dialog box when you are prompted. The .cab file will open and install automatically. Answer questions when you are prompted during setup. WARNING Do not attempt to turn off or restart the device while the update is in progress. After applying a ROM update, do not attempt to restore a backup that was made before the ROM update was installed. Method 2. Updating your Pocket PC while connected to a desktop computer Ensure that the device is docked and connected to
Sep 07, 2005 | Toshiba e310 Pocket PC
HTC Touch Cellular Phone Logo
55 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
