Question about Brother MFC-5840CN All-In-One InkJet Printer
Unable to clean error message
The printer stopped printing and showed the above error messages, I have thoroughly checked the machine and there is no paper or foreign objects stuck, I have removed and replaced ink cartridges, nothing is working. The printer is not connected to the fax line however I have checked for faxes and it shows nothing. We are a business and urgently need to get the printer working.
  • 33 Answers
Just swith of the printer even the swich of the main switch where the printer's plug is connected wait for 40 second then power it on again it will start working again if everything is connected perfactly
Posted on May 07, 2010
I CAN'T GET MY BROTHER ALL IN ONE TO COMUNICATE WITH MY COMPUTER
Posted on Jul 19, 2010
What are printer error messages 4F and 48 on Bother MFC-J430W wireless printer
Error 4F and Error 48.
Actual Message will be:
Unable To Init 4F
Unable To Clean 48
These messages indicate the Waste Ink Tank is full.
This is the space in your machine that will store all the ink that is used in cleaning the printhead. Once this is full the only way to continue printing is reset the Purge Counter and clean out the Waste Ink Station. If you do the reset and not he cleaning of the waste ink station you will eventually end up with the waste ink tank overflowing and leaving a huge mess to clean up. If you clean out the tank but not reset the purge counter it won't work till then.
Unless you are satisfied with your ability to dismantle and reassemble your printer you may want to just replace it as it can take some time and causes alot of mess.
May 01, 2016 | Brother MFC-J430w Inkjet All-in-One
Unable to print 48
Clean the plastic encoder strip thoroughly
In order to access both ends please follow these steps
1. After the error message is displayed on the LCD or display, open the scanner cover, so the print head is visible.
2. Press and hold the Stop/Exit key for 5 seconds. The print head will move to the middle.
3. Unplug the power cord from the power outlet.
4. Use a clean lint free cloth dampend with a bit of alchohol and clean both sides of the encoder strip thoroughly. Move the print head from side to side to allow access for cleaning of the entire encoder strip.
Feb 25, 2014 | Brother MFC 6490CW InkJet Printer
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
My printer won't print. It will also say "unable
Ok, for the printing part you should check the following:
-connection between printer and computer
-make sure the machine is not in power save mode
-make sure machine is online; click start, printers, choose printer and make sure 'Use Printer Offline' is unchecked
-reinstall the drivers from here: http://welcome.solutions.brother.com/BSC/public/as/au/en/model_top/colormfc/mfc5490cn_all.html?reg=as&c=au&lang=en&prod=mfc5490cn_all
Now regarding the scan error, seems to be a mechanical error. Remove and objects that might stop the scanning to proceed. Also, check the manual for Troubleshooting on the link above.
Nov 14, 2010 | Brother MFC-5490CN Flatbed Inkjet...
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
Brother 130c print unable 50
Solution #1 is absolutely spot-on from adnanbhatti, copy the link into your browser to be able to see the photos of the printer and how to slide the print head:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=11
When I slid the print head over as specified, I found a little crumpled paper fragment soaked with ink. Pulled it out.... I turned on the printer, it ran a cleaning cycle automatically, and started printing just fine!
Aug 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean
Hi, I tried the solution above "by obiewan" it work's for me but I do a little changes on his pattern.
1. Unplug your printer
2. press down the menu/set then plug it (just keep oh pressing it down until you see the message error 46 show up on LCD)
3. press 80
4. then look for "Purge", i think its on the 25th when you scroll down
5. then reset the pruge count to "0" by pressing 2 7 8 3
6. then press stop/exit
7. then press 9 twice
VOILA!!!
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
301 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
