Question about Ovens
I have a cooker with a bayonet fitting that wan't connect the the wall because the wall has a screw fitting what part do i need to connect the cooker to this ?
  • 269 Answers
You need to check with your hardware store and get a fitting compatible with your fitting on the stove.This will have to be fitted to the wall pipe but I stress that this should only be carried out by a registered gas fitter.
Hope this helped.
Posted on May 12, 2010
Change light bulb smeg oven
The glass bulb probably is a bayonet or screw fitting.
Nov 25, 2017 | Ovens
Flavel milano e60 how to fit new fan oven element that is riveted
That is complete RUBBISH the screws are accessible from the rear of the oven. At the back remove the screws holding the plate and you will see the element housing. Remove the two screws and the spade connections. Get someone to hold the new element in place for you and attached the screws. Fiddly job so be patient. Connect the spade connections and replace all plates front and rear. Should be the job!!! Someone hold the element in the cooker whilst someone connects at the back. Whatever you do, DON'T TAKE A DRILL TO YOUR COOKER!!
Dec 13, 2012 | Ovens
We have a multifunction freestyle over 698 and want to change the light inside the oven. how do we do this
The glass cover over the bulb should screw off, remove the bulb and replace it with a new one of the correct type. Clean and replace the glass cover. Be careful not to use force which could break the glass and cause an injury. Make sure that the stove main switch is off. (The lamp cover may have a screw type or have a bayonet fitting).
Jan 17, 2011 | Ovens
What does it mean when a gas cooker needs hardwiring
It means that it does not have a cord and a plug to just plug it into a wall socket...
It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
heatman101
Dec 13, 2010 | New World G60m Gas Single Oven
Locked oven door to clean. Need instructions to
These might help you get the door off
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Dec 22, 2009 | Ovens
Can I connect my Zanunussi zkc6040x cooker with 2.5mm T&E into my cooker outlet switch that is powered by 6mm and runs about 25`to the fuse box? Thanks.
No. It must be 6mm t&e cable from the wall socket to the cooker. To use anything else will rick getting an electric shock.
Sep 10, 2009 | Ovens
Control panel light problem & clock setting
Hi
to change the light tube and starter you need to remove the front control panel by the screws underneath it and at the side the yo can get to the light for the clock just press the first 2 buttons on the left and either + or - hope this helps you
regards
Mar 18, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
