Question about Technics SCEH790 CD Shelf System
Cd door not opening
Its 5 cd changer, not used for a while....cd door stuck not opening
    Problem Solver:
  • 19 Answers
It might be a sticky mechanism inside the unit. open it up spray a little WD40 on to the tray mechanism and should work (protect laser while doing it). A REPAIRER WILL STILL FIX THE UNIT EVEN IF IT HAS BEEN OPENED
Posted on Mar 25, 2011
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
My dics dor to its changer wont close
open it up
the tray has somthing stuck init
Mar 02, 2010 | Sony CDP-C445 5-Disc CD Changer
The cd door is stuck as if a cd is out of place. Won't open enough to see the problem.
Before, when trying to see the problem, I clicked "skip" to see if it would go through all the discs. It did, but still wouldn't open the door. Later, I clicked "play" each time, then "skip", and after going through all 5 discs, the door opened. Go figure.
Dec 19, 2009 | RCA 100-Watt Stereo System With 5-CD...
My rca rs 2657 cd changer is stuck. door will not open. any ideas how to correct?
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Oct 17, 2009 | RCA 100-Watt Stereo System With 5-CD...
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | Audio Players & Recorders
Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
Apr 02, 2009 | Sony CDP-CE375 5-Disc CD Changer
Open, closes and rotates the cd compartment, endless...
If there's a disk left over inside, It's stuck in the drive hanger, and should be removed else the changer can't put it back in it's right slot. Open the machine and check for any CD's still inside.
If not, could be that the small sensore (to the left of the head assembly (just before the drve (upside down)) is dirty or messed up.
Try cleaning if.
Jan 17, 2009 | Technics SL-PD687 5-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
My rca 5 disk vertically stacked cd changer is stuck. Won't open. How to fix it?
Try this... unplug the unit and turn it upside down.  Have a small screwdriver ready.  No plug the unit in and try to turn the wheel in the large slot clockwize.  When you see the spring clip try to grab the white plastic stop and move it clockwize.  This should eventually open the door.  It did for me.
Aug 03, 2008 | Thomson RCA Bookshelf System with 128 MB...
Technics SCEH790 CD Shelf System Logo
248 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
