Question about Thetford Norcold DE0051 Refrigerator
When on gas smells of exhaust fumes in van and
When on gas smells of fridge exhaust fumes in van and black soot on side of van
fridge works well though
  • 4,793 Answers
Sounds like the burners need a good scrub to clear carbon off jets.
Posted on May 07, 2010
I took my blend air 11 Coleman stuff off my furnace now furnace smells bad and filters are black with is wrong
Not clear on what you took off ? The black could be soot the smell could be fumes !!
Sep 15, 2016 | Heating & Cooling
Just developed a massive miss fire smells hot and black soot in exhaust
Running rich too much gas in mixture and not air this causes your problem. The black soot is carbon from the gas
May 20, 2016 | 2001 Citroen Xsara Picasso
I HAVE A 1995 CHEVROLET CAPRICE CLASSIC, UNDER THE DRIVER SIDE OF CAR IT SMELL OF GAS FUMES.
Gasoline or exhaust fumes? If exhaust, you have a leak. If gasoline smell, tank may be over full and vent may be clogged.
Feb 26, 2015 | 1995 Chevrolet Caprice Classic
Vehicle smells like gas both inside and out of car after engine is off. Check Engine light is on but no noted deficiences noticed, all fluid levels good. what could be the problem?
If your check engine light is on when the car is running, then that means there is probably a trouble code stored in your vehicles computer. With a code reader, you can find out what the code is. That will direct you to the problem. You can post your code here and we will tell you what it means.
Regarding the 'gas' smell, first check to see if your car is running 'rich'. You can rub your finger inside the tailpipe and see if there is a lot of black soot there, which would indicate its running too rich (too high of a fuel to air mixture). If this is inconclusive to you, remove the spark plugs and check if they are with black soot on them where the pin is. This will tell you how the engine is running in terms of fuel mixture. If they are black, then you have found the problem (fuel injection problem or Oxygen sensor, most likely). The trouble code might also point to this. Other than that, sometimes an exhaust leak can cause fumes to leak up into the car when running. My car had the gas smell problem and it was both a hole in the exhaust under the car and an overly rich fuel mixture. I had black soot inside the tailpipe and black sooty spark plugs and the final problem ended up being a bad oxygen sensor (located on the intake manifold), that was sending an improper signal to the vehicle's computer, thus the reason for the problem.
Sep 24, 2009 | 1996 Dodge Intrepid
Gas fumes
chech the fuel pressure regulator,its black incolor and has a vacuum line to it.It will be in the fuel rail.start the van and pull off the vacuun line, if fuel comes out its bad.
Feb 01, 2009 | 1999 Oldsmobile Alero
Gas fumes come into my nissan quest van
notorious fuel injector problems. should have a recall for you.
Dec 23, 2008 | 2005 Dodge Sprinter 3500 Standard Roof
Thetford Norcold DE0051 Refrigerator Logo
464 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
